Sponsored by:
Sponsored by:
New rear tire - car pulls to right?
Old Aug 2, 2005 | 11:22 AM
ras2k's Avatar
Default New rear tire - car pulls to right?
I need help!!!!
I had a leak in the sidewall of my rear left tire, so ordered a new tire. I had it installed, and went ahead and had an alignment done to factory specs at the same time. The right rear tire has about 60 % of the tread left on it. I have Yokohama AVS-ES100, 255/40/17 inches on the back and 225/45/17 on the front with Volk CE28N rims.
The car now pulls to the right. After taking the car back to Butler Tire in Atlanta (actually Austell), they said it was due to the difference in circumference of the new left rear tire vs the old right rear tire.
Does this sound correct? To prove it, I had them switch the left and right rear tires just to see. I realize these are uni-directional tires, but I only drive it for about a block to see if I could notice any difference. I did - it pulled to the left.
Are out cars that sensitive to pull if the circumference of the rear tires are off by mere millimeters? Does this sound correct, or do you think I have a bad tire?
Old Aug 2, 2005 | 11:53 AM
WestSideBilly's Avatar
Yes, this is correct.
The smaller (old) tire must roll faster to go the same distance, which the Torsen LSD perceives as slippage, and sends extra torque to the larger (new) tire, causing it to pull under acceleration. Just 1/10" of wear would make the new tire 1% larger, which is enough to throw the LSD off. You likely have 8/10" disparity in the diameter, making a 3.3% difference.
Moral of the story - always replace drive tires in pairs.
Old Aug 2, 2005 | 11:55 AM
jedwards's Avatar
Billy is right. I've got this going on right now too. I replaced my left rear last week. My right rear is now on order.
Old Aug 3, 2005 | 05:55 AM
ras2k's Avatar
Thanks for the replies. I'll order a new right rear.
Old Aug 3, 2005 | 06:46 AM
jedwards's Avatar
I get mine on this morning.
Old Aug 3, 2005 | 09:40 AM
ras2k's Avatar
Let me know if this fixes the problem.
Old Aug 3, 2005 | 10:15 AM
jedwards's Avatar
Just left the tire shop and drove 20 miles up the 680. Let my speed drift along at 70... down shift and hammer it... nothing. Straight as an arrow. Lift off and no push the left either.
All fixed.
Old Aug 3, 2005 | 10:38 AM
Old Aug 3, 2005 | 10:51 AM
jedwards's Avatar
Old Aug 3, 2005 | 12:10 PM
ras2k's Avatar
All fixed.
Great news !!!!! Thanks.
Now that I have a couple hundred miles on with the new left rear tire, will I have another problem when I order the new right rear tire? I can't imagine that the treadwear will be that signficant.
