presistant odb2 code: P1457
Old Aug 3, 2005 | 06:40 PM
jah's Avatar
jah
Default presistant odb2 code: P1457
P1457 ????
thanks
Old Aug 3, 2005 | 06:42 PM
Planets's Avatar
looks like leak in the evap system... is your gas cap tightened all the way down?
Old Aug 3, 2005 | 06:51 PM
Slows2k's Avatar
A loose gas cap WILL NOT set a P1456.
The 1457 is a evap leak on the canister side of the Evap system. The most common cause for this DTC in climates that have snow is a rusted/corroded EVAP bypass solenoid. It really needs to be checked out by a qualified and experienced Tech to properly dianose this system.
Old Aug 3, 2005 | 07:40 PM
jah's Avatar
jah
P1457:
got this about a mo ago, been ridng the bike tho till today's rain. the err code did not go away on its own, it stayed up a long time till a manual clr today. good to get rid of the err, will not have fun in the safe mode.
probable cause = EVAP canister & the related system of hoses & valves bad? any idea of most porbable things to ck.
alot of posts to the effect the valve on top of the canaster not working.
Bliss@5200
Dec 6, 2011 01:00 PM
s2k rookie
Sep 21, 2007 02:57 PM
s2k_aristo
Feb 14, 2007 03:01 PM
jah
Aug 11, 2005 09:05 PM
rhood
Feb 8, 2005 04:12 PM
