Valve tapping noise from Over-rev?
Old Aug 15, 2005 | 07:53 AM
StockSH's Avatar
Default Valve tapping noise from Over-rev?
I think I over-reved (2nd to 1st) last month. I still can't believe anybody on earth could shift to 1st gear instead of 3rd (not easy as 3rd-2nd shift).
anyway It was a very short over-rev.
man..I can swear it was a 3rd gear.. it resisted a little so I forced it (oh..I had a water bottle in cupholder).
my idle was fine. car still pulled strong. that was a month ago.
I found out (I just paid attention) that I could head little tapping noise.. (it sounded like my 100k miled prelude)...
Am I in trouble? I'm gonna adjust the valve soon..I hope they could check for retainer and valves by just taking the valve cover off...
oh how much for valve adjustment also~ thanks
Old Aug 15, 2005 | 07:59 AM
oakfloor's Avatar
You might want to check the valve lash, and valve spring retainers for cracks.
Old Aug 15, 2005 | 08:39 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
A broken retainer will give no initial signs. It will just let go at any time. I've caught one car early enough, and just did retainers.
You can't see the actual crack in the retainer. But you can see a retainer that has walked upwards on the keepers. Only thing needed is to pull the valve cover, and a dentist mirror will also help.
Old Aug 15, 2005 | 10:19 AM
mad-dog-one's Avatar
Stop running the damn thing and spend a few hundred $ to have someone look at the retainer clip that billman250 described before you risk needing a $9,000 engine overhaul. PM billman250 and see what he recommends.
Good Luck
rikhemi
Nov 24, 2014 05:25 PM
Boss-S2K
Jun 4, 2013 05:14 PM
jonnys2k01
Dec 1, 2008 05:17 PM
smile
Aug 1, 2004 09:41 AM
