Part II: J's Header T1R Test Pipe J's Tit. 60RS
Old Sep 1, 2005 | 05:26 PM
bluetooth's Avatar
Default Part II: J's Header T1R Test Pipe J's Tit. 60RS
Part I can be found here: https://www.s2ki.com/forums/index.php?showtopic=318448
Now the T1R Test Pipe, with the Anti Fouler Plug (you can't see the Fouler because one was getting drilled by a 1/2 inch bit at that time)...
Is this stock?
The Cusco stuff...
Tit. 60RS coming alive!
I would also like to thank AJR up in Canada for supplying me with all the J's goodies. Ben, you the man! Dickson, you the man also! There service is second to none, just like Anthony's Shop! They are straight up guys!
Next on my list is to put the J's airbox in. Just sitting at my office. Now if I have time again. hmmmm untill next time....
Old Sep 1, 2005 | 05:55 PM
fshwcrs's Avatar
weeee neeeeeed sound clips
looks awesome!
Old Sep 1, 2005 | 05:58 PM
ep3minivan's Avatar
I agree. We need some sound clips. I have been anxious to hear the full J's exhaust with the 60rs.
Old Sep 1, 2005 | 06:04 PM
hksupersi's Avatar
bluetooth: are you able to still use the that cat heat shield w/ a race header instead of a test pipe. thanks.
Old Sep 1, 2005 | 06:06 PM
FIZZ-AP1's Avatar
very nice parts feel any difference with the Cusco bars?
Old Sep 1, 2005 | 06:17 PM
Kel's Avatar
Kel
Looks like the Spugen install bay.
Old Sep 1, 2005 | 06:32 PM
bluetooth's Avatar
looks awesome!
I have sound clip! but i don't know any host to put it up? I can email it to some one, if they like to do it. Thanks!
Old Sep 1, 2005 | 06:33 PM
bluetooth's Avatar
NO, there is no heat shield for the header like the mugen...
the only heat shield is the one that goes between the battery and the header, J's makes one like this (sorry the pic is bad).
I forgot, I also installed this...but was having fitting problem. It was rubbing one of my headers. I try to adjust it but no luck for me. Also it was rubbin on the other side, it looked like a servo of some kind that contected to the aircond. pipe is. So now I went back to the stock one and that gave me about 1/2 inch clearance. I also drilled a whole on the stock heat shield like the J's heat shield. Weight difference is very minimual compared to the J's. Reason for drilling whole is that I got the J's engine damper (Thats also next project).
Update, just got this today. Here is some comparison.
Other side.
Sideways view.
Wieght differences, 0.2 lbs...
J's 0.9 lbs. The whole is 2" and 1/4' inch diemeter.
Stock, 1.1 lbs. the whole is 3" inch diameter (I requested that size, just in case so there can be some free play, with the engine damper)
Old Sep 1, 2005 | 06:36 PM
prheemo's Avatar
nice Tit......60RS
Old Sep 1, 2005 | 06:37 PM
bluetooth's Avatar
Yes there was a difference on the cusco bars. the big notice was that when I go up to my drive way I would hear little creek, and now no more...for now. i need to go up angeles crest (mountain) to really test this baby. probably this weekend i will go up. i couldn't really do any tight turns, since i was in traffic most of the time. felt it tight but can't really explain it.
