Question
Originally Posted by shakes,Nov 21 2005, 09:59 AM
The rim was dom out what does that mean? and arent the offsets on s2000's suppose to be like 50+ in front and 65+in the back I was told that from many people.
Originally Posted by dmpts2k,Nov 21 2005, 02:09 AM
that my lil bro car, it is axxis seven. i believe it was 3.25 inch lip in the rear. offset is 40front 37rear . the rim was dom out. that why that offset worked
Originally Posted by shakes,Nov 21 2005, 02:51 PM
You need those offsets if u plan on dropping the car low inside the fender and also without rolling the fenders. What size are the wheels in the pic?
the offsets you stated are somewhat optimal, but are not 100% nessecary...if you wanted to go with like a 9.5 or a 10 in the rear. then you'd have to go even higher then the offset you stated and be in the +70 area... if you went with a 9inch rear.. then you'd want to be in the 60's, but upper 50's would work..
and if you're running a bbk in the front (depending on the style of spokes on the wheel) you'll have to run a lot lower offset... (in the upper 30's)...
