MY2006 Technical Differences
Old Dec 5, 2005 | 04:14 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Default MY2006 Technical Differences
Had an 06 out today, couple of things I noticed:
the obvious:
DBW (electronic accuated throtte plate) This means the IAC Valve has been eliminated, along with the cruise control hardware. It is all controlled by the ECU.
A gas pedal cable runs into the engine compartment to an actuator. From there it's electronic
not obvious:
-New intake manifold, intake support bracket, and injector cover
-There is only one cam sensor
-New style map sensor
-IAT sensor has moved to the rubber intake tract
-The dif now has a breather box mounted behind it
-fuel line at engine is now a quick-release type
-The air pump, associated lines and and control valve, have been eliminated
-there are weight/and or/position sensors mounted in the seats
Other stuff I've confirmed:
-The fan switch in the radiator has been replaced with a second CTS, in turn the fans are now computer controlled
-The HO2S in the header is now reffered to as an Air fuel ratio sensor
-if you leave the gas cap loose, you'll get a "CHECK GAS CAP" warning, displayed in the outside temp display
Added by members:
Valve cover is a new part number
Feel free to add to this thread, and myself of Slows2k will copy it to the main list
Old Dec 6, 2005 | 06:06 PM
Slows2k's Avatar
I beat you to it Billman :
https://www.s2ki.com/forums/index.php?showt...iew=getlastpost
I'll merge the threads when they fill out some more.
Old Dec 10, 2005 | 03:54 PM
jlucas's Avatar
Valve cover is a new part number.
Old Dec 16, 2005 | 03:26 PM
Squeezer's Avatar
quick disconnect on the fuel line? does that mean I have to use one of these to undo the fuel line:
if so, I hate using those quick disconnects, they are a pain in the butt.
Old Dec 16, 2005 | 05:50 PM
Slows2k's Avatar
A small pocket screw driver works well on the Honda push connect fittings.
Old Feb 20, 2006 | 04:22 PM
Nimbus's Avatar
'06 intake airbox interior chamber is different.
Old Feb 21, 2006 | 12:23 PM
03_AP1's Avatar
Interesting......what measures have been added to keep the cold start emmissions to a minimum? (the reason for the air pump in the first place.....)
Old Feb 23, 2006 | 12:31 AM
jzz30's Avatar
the air filter is new. instead of a rubber/plastic wiener at the it of the filter it has a cross shaped mount in to the new box.
but the K&N filter will work with some forcing in. (not hard at all) oh and the intake hose/pipe has a spring around to secure the air filter.
allansteele
Jan 12, 2016 06:31 PM
unclefester
Jun 13, 2012 12:41 AM
Serg2K
Aug 3, 2011 11:40 AM
nsxracer
Dec 3, 2007 07:10 PM
B SweepeR B6
Dec 23, 2004 05:14 AM
