Official off topic bantered planning thread
In a few hundred miles it will stay on rather than flash. This is a reminder to change your oil. The reset procedure is in the manual. Essentially, (with car off) press and hold odometer clear button. Turn key as if you were starting the car. Wait until the light goes out, then release button. Go have a drink.
It's just a reminder light . Nothing is wrong with your car , it just "thinks" you haven't had an oil change or scheduled maintenance recently and flashes mainly to annoy you
Here's how to reset it : key in the ignition - press and hold the TRIP/RESET buttons (lower right corner of gauges) - turn the key to ON while still holding the two buttons - hold them until light stops blinking (10-15sec) . Then turn the key back to OFF and then start the car as normal - the light should be gone
.Here's how to reset it : key in the ignition - press and hold the TRIP/RESET buttons (lower right corner of gauges) - turn the key to ON while still holding the two buttons - hold them until light stops blinking (10-15sec) . Then turn the key back to OFF and then start the car as normal - the light should be gone
