My New AEM V2 has a drain hole.... (Pics)
Old Feb 11, 2006 | 11:18 AM
SiCK HONDA's Avatar
Thumbs down My New AEM V2 has a drain hole.... (Pics)
After opening my AEM V2 today (Thanks, Evasive!), I started to install and realized that there is now a hole drilled out where the elbow bends up (lowest point) after the filter... !!
There is a "duckbill valve" that apparently gets stuck into this hole, although I can't see how the water that may build up can get out...??
Maybe I need to trim the bottom to allow water to drip out??
Anybody elses come like this?
Sweet!!
-Matt
Old Feb 11, 2006 | 12:33 PM
TriaXenginE's Avatar
probably when people were blowing motors due to the design. that's one class action suit prevented.
Old Feb 11, 2006 | 01:04 PM
rsaeini's Avatar
yeah mine is also like that.
that duckbill plug has a slit in it to allow the water to drain.
Old Feb 11, 2006 | 05:41 PM
soozookabluS2k's Avatar
hey im thinkin bout pickin that intake up. Wuts ur honest opinion since u just got it installed. Any gains at all? How about the sound, i heard it was real loud.
Old Feb 11, 2006 | 05:42 PM
riceburners2001's Avatar
damn!! mine doesnt have that thingy..
ah well ive put a shield thingy on top of the air filter so no water can get in
Old Feb 11, 2006 | 05:44 PM
MULDER's Avatar
I bought a Comptech
Old Feb 11, 2006 | 07:06 PM
TheCarGuy2021's Avatar
wouldda bought a v2 if i knew that... btw you should do something about those swirls
Old Feb 11, 2006 | 07:19 PM
WPS's Avatar
WPS
kind of confirms the design flaw. i wonder if it sucks dirty air through the slit. it's not as tight as a filter
Old Feb 11, 2006 | 08:33 PM
rsaeini's Avatar
i used to have a comptech and i switched to the V2 about a month ago.
i like the intake. it's louder than the comptech and i think it works a little bit better.
the butt dyno says it make more power and on the dyno it made more torque and more power across the entire power band...at some points it made about 5-6 more hp. but peak power barely changed. see dyno graphs below.
with AEM V2 intake and T1R exhaust w/ test pipe
with Comptech intake and T1R exhaust w/ test pipe
Old Feb 11, 2006 | 09:26 PM
^^^awesome, thanks man
