Creaking in the rear suspension
Old Apr 9, 2006 | 05:09 AM
M32's Avatar
M32
Default Creaking in the rear suspension
I have noticed that my rear suspension has been "creaking" whenever I first back out of my drivewayor when I go over speed bumps. When this first started happening, I was on espelir springs and stock shocks. I had initially thought it was either the rubber bump stops or the upper mount so I switched my suspension set up to Apexi coils... and it STILL HAPPENS. Anyone experience the same thing? If you did, please shed some light on how to fix this. Thanks!
Edwin
Old Apr 9, 2006 | 05:19 AM
mwilly00's Avatar
I've got the same problem. I've got expelir springs on stock shocks with spc ball joints and the creaking is bugging the hell out of me. I've greased all the joints in the suspension now twice and its still there.
Anyone know how to fix it?
Matt
Old Apr 9, 2006 | 10:21 PM
passmans2kny's Avatar
i have jic coilovers and i have same noise, especially when im turning and putting more load on one side than another
Old Apr 9, 2006 | 10:24 PM
dyhppy's Avatar
it sounds similar to a sound i had. it sounded like it was coming from the back but it was actually my hood latch.
Old Apr 9, 2006 | 10:34 PM
espelirS2K's Avatar
I have the same thing! Espelir springs.. stock shocks.
I keep thinking it's the coil spacers from the factory.. but.. It's aftermarket shocks, and I sure hope the spacers haven't been there for the pat 5 years .
I'm really interested to see where this goes. Input anyone?
Old Apr 10, 2006 | 07:06 AM
S2nOC's Avatar
same here, but everything stock 04, backing out the driveway and while turning the wheel, slowing down while turning into the driveway, making turns. noise sounds like coming from rear right. like everyone else, input?
Old Apr 10, 2006 | 07:33 AM
aznprydefloz's Avatar
I've had the same problems as well, but suddenly it stopped happening for me.
Old Apr 10, 2006 | 07:35 AM
nightcrawler7188's Avatar
i have completely stock suspension and it happens, but only when going over big speedbumps slowly.
Old Apr 10, 2006 | 08:09 AM
M32's Avatar
M32
I thought it was the bumpstops so I switched out the whole suspension. I Am now thinking it's the bushings in the back
Anyone else have any input?
Edwin
Old Apr 10, 2006 | 08:17 AM
jasonjm's Avatar
Press against your hood. Does it creak?
If so get some real grease, not spray type. Grease the hood latch.
I was squeaking and two trips to the dealer with no solution. Then I just greased the latch, problem solved.
Note, spray lube won't work as good and in my case didn't work at all.
