Another weight reduction topic
Old May 8, 2006 | 07:55 AM
s2ktarga's Avatar
Default Another weight reduction topic
I wanna get everyones opinion on how to get my 2005 from 2850lbs to 2700lbs.
Keeping a budget in mind.
Thanks In advance
Blessings
Old May 8, 2006 | 08:03 AM
WVtwisties's Avatar
buy a dremel and start using it!
jk
someone's bound to link you on this topic..but from my knowledge..single exhaust is a good start and there are plenty of interior items that aren't necessary...spare tire was the first thing i did.
good luck
Old May 8, 2006 | 08:06 AM
s2ktarga's Avatar
Oh ok.
Spare tire gone.
Im actually running single (stock muffler)
Does anyone know what the softtop wieghs?
Old May 8, 2006 | 08:13 AM
WVtwisties's Avatar
few other things i'm thinking of but don't know exact weight savings..
air conditioning is big
soft top is a heavy item but needs replaced with hardtop so net savings is probably minimal
passenger seat
sun visors
air bags
depends on how extreme you're getting
Old May 8, 2006 | 08:26 AM
CRDMS1's Avatar
Net savings on the factory hardtop (w/soft top completely removed) is about 20lbs. IIRC. Someone actually did the exact weights a year or two ago, but I can't find the thread. You could probably save another 10lbs. or so going with one of the CF hardtops available, but that's VERY expensive weight savings.
Lighter wheels are always a good thing. You can drop 5-10lbs. per corner quite easily and inexpensively if you so choose.
The CF hood and trunk don't seem to add up to much weight savings IIRC.
Old May 8, 2006 | 08:33 AM
Nobody's Avatar
-25 Spare Tire
-6 Trunk Trim
-10 Tools/Jack
-5 Mats/Visors
-30 (5 Gal Gas)
-12 Optima Battery (PC680)
-7 Washer Fluid
-4 Front Hood insulator
-5 Cruise Control Unit
-5 Center Console
-10 T1R test pipe
(100+ lbs, mostly free)
-15 Recaro SPG
-10 Stock Rollhoops/Plastic
-30 Wilwood 4 Pot Brakes
-5 Flywheel
-15 Sparco Seat
-18 Tein RA
-15 Volk Rims
-33 T1R exhaust (stock: 51.5lbs, T1R: 18.5)
-20 AC Compressor + lines + Radiator + Fluid
-5 AC Evap Core + rubber hose + Radio Switches
-15 Header
-15 Airbags
-20 HT (Soft top weighs 65lbs w/motors)
-14 (Rear sway bar and windshield wipers/motors)
-127 Gutted doors
Old May 8, 2006 | 08:36 AM
s2ktarga's Avatar
how much of the door can you gut?
Old May 8, 2006 | 08:41 AM
s2ktarga's Avatar
Wouldnt it be bad if you take off the rear sway bar?
Old May 8, 2006 | 08:42 AM
WVtwisties's Avatar
Originally Posted by Nobody,May 8 2006, 08:33 AM
-25 Spare Tire
-2 Trunk Trim
-7 Tools/Jack
-1 Mats/Visors
-30 (5 Gal Gas)
-2 Washer Fluid
-5 Center Console
-10? T1R test pipe
(103 lbs, mostly free)
-15 Recaro SPG
-5 Flywheel
-15 Sparco Seat
-18 Tein RA
-15 Volk Rims
-15 Header
-15 Airbags
-127 Gutted doors
there ya go!
should be a faq stickie
Old May 8, 2006 | 08:54 AM
Nobody's Avatar
That's what I always thought. All the blazingly fast mofos out here on the west coast recommended removing the rear sway bar due to rear wheel lift. In corners, all the power goes to the wheel off the ground and you lose drive out of corners. I've had a little wheel lift, but not much, so I left mine on--until last Fri. I was getting MASSIVE amounts of wheel lift, so I figured what the hell and disconnected the thing. Didn't have any issues with rear wheel lift after that...just had some issues with understeer, which should be fixed when I remove my Saner and go with the stock front bar.
