California - Southern California S2000 Owners Southern California S2000 Owners
the infamous clicking problem! edit:SOLVED
Old May 15, 2006 | 05:14 PM
if lookz kill's Avatar
Default the infamous clicking problem! edit:SOLVED
i've read up on this many times, and the search is a piece of crap so i need your help if you have this in your favorites.
i have this clicking issue near the rear of my car, mostly whenever i'm at a stop and then i start going and taking a right/left turn. i have a feeling it's something with the diff? i forgot... anyways, i'm sure most of you OG S2K owners know what i'm talking about.
isn't there a honda "whatchamacallit" bulletin print out thingy i can take to honda for them to fix this?
btw: i'm a 2001 under 30k miles thanks
EDIT!!!
https://www.s2ki.com/forums/index.ph...T&f=5&t=361479
That product fixed my problem. I no longer have the "clunk clunk" sound.
If you want brand name, J's also sells this identical product which is actually a little better quality but for $220. I personally would have purchased the J's if I knew beforehand. Oh well, good luck to all!
Old May 15, 2006 | 05:26 PM
ahbongkadah's Avatar
Could be your axle nut. Needs to be re-torqued to 220lbs. If that doesn't fix it, might be your dif, or even just something as simple as brake pads moving around.
Hope it works out for you
Old May 15, 2006 | 05:29 PM
Here is the TSB:
Axle Pops or Creaks:
Old May 15, 2006 | 05:40 PM
tool462's Avatar
[QUOTE=ahbongkadah,May 15 2006, 06:29 PM] Here is the TSB:
Old May 15, 2006 | 05:52 PM
GrimReaper's Avatar
From your description, it sounds like it could be the CV joints.
https://www.s2ki.com/forums/index.php?showtopic=39249
https://www.s2ki.com/forums/index.php?showtopic=241367
I don't know if there's a TSB on it, but here's the list
https://www.s2ki.com/forums/index.php?showtopic=103975
All courtesy of the FAQ section in Under the Hood.
hth
Old May 15, 2006 | 05:53 PM
NFRS2kSi's Avatar
it could be from loosen nuts on exhaust system. sway bar endlink.
Old May 15, 2006 | 10:50 PM
hth
that's what i was looking for. thanks
Old May 16, 2006 | 05:50 AM
klee1113's Avatar
Originally Posted by tool462,May 15 2006, 05:40 PM
Does this only apply to 00-02? My 04 makes this noise as well.
mine does this too... its quite annoying
Old May 16, 2006 | 07:09 AM
ToeKneeC's Avatar
me 3. maybe when we get it smogged this wk i'll have the mechanic retq the nuts.
Old May 16, 2006 | 07:37 AM
FlameDoctor's Avatar
Funny how we all have the same problem at the same time. I started the following thread a few days ago:
https://www.s2ki.com/forums/index.php?showtopic=387565
I'm trying to get this problem fixed myself. Looking for anyone with 36mm socket and torque wrench that can torque up to 220 ft-lbs. I'm still offering a twelver of your favorite beer for your trouble, so long as you enjoy one with me! There are others on that thread trying to get this fixed as well.
I'm located in Huntington Beach.
