Mark this thread as Sold
Mint Enkei TR F3 Silver, 17s and tires full tread!
Old Jun 18, 2006 | 03:02 AM
SilverKnight's Avatar
Exclamation Mint Enkei TR F3 Silver, 17s and tires full tread!
Its rare to find an aftemrakret wheel with the same exact offsets as an Ap2 17 rim.
$1795 + shipping for mint rims and 98% tread
The Specs are:
5-114 bolt
17x7 front and 55+ offset
17x8.5 rear 65+ offset
You do not need to lower youre car with these rims. No crazy wheel gap as it is same offset as stock. so if you want aftemret but dont want to lower than get these these rims
I also got:
Fuzion ZR
225/45
and 255/40 for extra traction.
You can use stock lugs with these also and also stock wheel caps will fit. Weight is around 15lbs for rim.
Here is a pic of the rims but it is at an angle, no straight sahots yet but def an aweosme set and you can go auto cross or track with these rims since they are same specs as stock.
whats wyatt doing in my s2k!!!
Wheels and Tires about 3 weeks old. Will sell $1795 + shipping.
whheels just got a 99% perfect balance job
Old Jun 18, 2006 | 09:25 AM
Old Jun 18, 2006 | 09:45 AM
Ubetit's Avatar
Do you have any better pics? Hard to tell anything with one wheel from that distance
Old Jun 18, 2006 | 09:48 AM
All the pics are from angles but I need to try to get some straight on shots but you can from one of the pics in the first post. Rims are hot and if your not lwoered then it will still look good an dno crazy wheel gap since its perfect offset
Old Jun 18, 2006 | 09:51 AM
using stock lugs which it perfect but you oculd go aftermarket for weight savings. The rim just bolts on as if its stock again exact specs as Ap2 rims so you can use them for track or auto x legally, but these are more lightweight and are aftermarket Enkeis
Old Jun 18, 2006 | 09:53 AM
Ubetit's Avatar
You mention using stock lugs. Are you sure these aren't taper seat wheels? Stock lugs shouldn't be used on taper seat wheels.
Old Jun 18, 2006 | 09:57 AM
wel they fit perfect and torqued to 80lbs. no probs whatsoever. Event he wheel guys liked it. An EVO IX owner the one I raced want them also, so he wil try to get these fit on his EVO.
Old Jun 18, 2006 | 10:01 AM
trivium's Avatar
Banned
Ummm how are these rare? cant anybody buy these off Tirerack?
Old Jun 18, 2006 | 10:05 AM
Ubetit's Avatar
Sure, you can get the stock rounded acorn seat lugs on your wheels, but they'll damage the edge of the taper seat.
