Bulb help!
Old Jun 30, 2006 | 02:58 PM
vroooom..psshhh's Avatar
Default Bulb help!
I just got some D2S bulbs to replace the halogens someone put in my s2k before I got it. Anyway, I am taking out the old bulbs and see that the connector looks like something from a wall socket. Obviously the connection isn't matching for the D2S bulb. I'm not a headlight master and I'm freaking out. It looks like they were spliced in at the wiring for the connector.
How screwed am I? Any place where I can buy a connector for these...quickly!
Please look at the pics I took. I know they are crappy, but its all I have.
http://pg.photos.yahoo.com/ph/muztangpride...m?.dir=/e076re2
Thanks
Old Jun 30, 2006 | 03:15 PM
JspecVtec's Avatar
wat bulb is that for? the high beams or corners or the HID lowbeams?
Old Jun 30, 2006 | 03:40 PM
I'm replacing the HID low
Old Jun 30, 2006 | 04:24 PM
camera obscura's Avatar
Are you sure? Did you have to remove the off-white circle shaped cover to access that bulb? Why in the hell would someone go from HID to halogen?
Old Jun 30, 2006 | 05:09 PM
[QUOTE=camera obscura,Jun 30 2006, 07:24 PM] Are you sure?
Old Jun 30, 2006 | 06:07 PM
nsxnext's Avatar
How come you never notice the HID being non existing?
Old Jun 30, 2006 | 06:12 PM
I thought they just didn't replace the headlight correctly. It looked like it wasn't producing enough light at certain times. I just recently went on a caravan and the person in front of me told me that they were not the HID's. So I put an order in and just got them.
I don't see many s2k's at night. So I didn't really have a comparison to notice how badly mine sucked.
Old Jun 30, 2006 | 06:56 PM
JaTe's Avatar
do ur lights "flicker" when u first turn them on? if so, then you have HIDs.
are you sure that you arent pulling the high beam bulb instead of the low beam?
something doesnt sound right.
Old Jun 30, 2006 | 07:25 PM
They definately don't "flicker". I just have to wait until morning to pull the thing apart again and see what my mistake was. Hopefully I figure it out cause it is driving me nuts.
I'll post comparison pictures too once and if I get them in. That way all you s2kers can see what misery i've had with these halogens.
Old Jul 1, 2006 | 07:22 AM
well I figured out what the situation is. There is no ballasts and they put the same bulb (H1) as the high beam in as a low and re wired it to work. Time to hunt for ballasts now
