Clicking rear end - Hub nut
Old Jul 2, 2006 | 08:04 AM
SiDHEaD's Avatar
Default Clicking rear end - Hub nut
Hello,
When i pull off (forward or reverse) there is a metallic click/creak from the back.
I mentioned this to the dealer when it went in for some other warranty work and they said they are going to have to have it in for 2 days to strip down the drive shafts and re-lube them. Does this sound right? It sounds the same as when the wishbone bushes went on my old Ford.
Old Jul 2, 2006 | 08:09 AM
uppitychick's Avatar
Sounds like the hub nut to me. (From what others have said).
Old Jul 2, 2006 | 08:17 AM
mikey k's Avatar
Hub nuts to brake discs moving
Both a know issues.
Old Jul 2, 2006 | 08:35 AM
Both a know issues.
You mean brake pads?
Old Jul 2, 2006 | 09:00 AM
SiDHEaD's Avatar
Could be discs, but i dont think pads, it's too metallicy.
Old Jul 2, 2006 | 09:29 AM
MB's Avatar
MB
Member
See my thread on grinding noise Andy. Seems to be getting rather common
Can just be the diff engaging but if its a loud click....
It wont be the pads, they are spring loaded and wont make that much noise IMO.
MB
Old Jul 2, 2006 | 10:14 AM
chilled's Avatar
My pads are moving and they're fairly metallicky.
Old Jul 2, 2006 | 10:17 AM
AquilaEagle's Avatar
Administrator
This is what you need to show them
http://www.s2kuk.com/technical/TSBs/Servic...or%20Creaks.pdf
Old Jul 2, 2006 | 10:37 AM
soulcrew's Avatar
clicking rear ends are the new black.
Old Jul 2, 2006 | 11:14 AM
mikey k's Avatar
I meant the pads, often they are not quite fitted right or the spring retainers don't quite hold them hard enough!
