Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Autocross - October 1
Old Sep 27, 2006 | 08:11 PM
patinum's Avatar
Default Autocross - October 1
There's an autocross at the College of Lake County on October 1st held by the windy city miata club. It's their last autox of the year and the weather looks like it will cooperate.
There's also an SCSCC autox at Maywood and WAI autox at Miller Park that day.
Windy City Miata Club
Salt Creek Sports Car Club
Wisconsin Autocrossers Inc.
Old Sep 28, 2006 | 09:18 AM
loudes13's Avatar
if i find a car to drive, i'll be at maywood with scscc. How does CLC compare size wise?
Old Sep 28, 2006 | 11:21 AM
Jirzlee's Avatar
I plan to go to the WAI at Miller Park Sunday. While you experienced guys are here, what alignment specs would you recommend for me? I have a few events under my belt and would like to get my car setup better for autox with some street use in mind. My car is a completely stock 2003, tires and all, only thing I've changed is the cat-back exhaust. I found the alignment suggestions in the Autocross FAQ (https://www.s2ki.com/forums/index.php?showtopic=172595) but I'd like to narrow down the specs so I know what exactly to tell the alignment shop. Also, are these specs per side or total toe or camber? Any recommendations?
As stated in the FAQ:
Old Sep 28, 2006 | 02:33 PM
loudes13's Avatar
to save wear on the tires, minimize the toe angles.
above will also be twitchy on the street.
0 front
1/4" in on the back is ok for me
camber looks good.
Old Sep 28, 2006 | 07:58 PM
patinum's Avatar
CLC is a bit smaller than maywood, but less gravel.
I've just been called out of town for the weekend, so I hope somone shows up at the CLC event to represent the S2k's
Old Sep 28, 2006 | 08:06 PM
PeaceLove&S2K's Avatar
Won't be me... I've been swamped at work, and will probably need to get some work done
BTW, from my one experience, CLC is also a *lot* wetter.
Old Sep 28, 2006 | 10:18 PM
Jirzlee's Avatar
0 front
camber looks good.
Ok, thanks for the feedback. So would that be 1/4" total toe in for the rear?
Old Sep 29, 2006 | 09:05 AM
loudes13's Avatar
I'm running close 3/8" total rear toe in. It's a compromise 1/4" total in will give better wear, but be slightly twichier. If you have a big front bar, you can tweak it perfect.
Old Sep 29, 2006 | 12:24 PM
tcho82's Avatar
Considering this is 5 minutes from me. I might go to this.
Old Sep 30, 2006 | 07:24 AM
Work be damned. I think I'll go to the WCMC event. I'll see you there if you decide to show up, tcho.
