Best brake upgrade for AP1?
Old Sep 28, 2006 | 06:35 PM
Akilldema's Avatar
Default Best brake upgrade for AP1?
I'd like to upgrade my braking system and had a hard time finding conclusive results searching for past threads. Does AP Racing make an applicable kit? What are the best possible upgrades out there? Street/Track use.
Old Sep 28, 2006 | 06:53 PM
SoCalJimS2K's Avatar
Along the same lines as this post, someone today offered me 4 new AEM drill rotors for $150. I saw the same AEMs on his Acura Integra. This strikes me as a good price but I'm wondering if any of you have a comment on the quality/desirability of an AEM system. Or should we all just say Brembo in unison? Thanks.
Old Sep 28, 2006 | 07:04 PM
Dark's Avatar
Stoptech makes a great kit.
You can also get Spoon calipers for the stock rotors.
Old Sep 28, 2006 | 07:14 PM
Master Bruce s2k's Avatar
How much of a diff. is there between the stock calipers and the spoon, in diff. i mean feel and so on. Thanks. (sorry if i jacked the forum >.<)
Old Sep 28, 2006 | 07:15 PM
GPS2K01's Avatar
I heard Spoonies didn't work even with AP2 wheels mounted....?
Old Sep 28, 2006 | 11:01 PM
s2ka's Avatar
The stock brakes are fantastic! The modulation is spot-on. The ABS functions perfectly without intrusion. The AP1 pads don't dust or squeal. Any more braking and all you get is tires locking-up without improving your braking distances on the street.
If you go to the track, just slap in some racing pads and Motul brake fluid and you can stop incredibly quick with very little fade.
Stock is pretty darned good.
Old Sep 29, 2006 | 01:09 AM
riokong's Avatar
I second that. Just get pads...Try a few different brands and you will find a set that you like.
Old Sep 29, 2006 | 03:48 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
http://www.brembo.com/ENG/HighPerformance-...nTurismoBrakes/
Old Sep 29, 2006 | 04:15 AM
Akilldema's Avatar
Any pad suggestions?
Old Sep 29, 2006 | 05:00 AM
DerrS2K's Avatar
Most BBK kits including Spoon do not work with stock wheels or many aftermarket wheels for that matter. With the special offsets on the S, it is just as difficult picking a BBK as it is deciding on rims that will fit it.
Wilwood 4-piston is the only BBK i'm aware of that fit OEM rims. Although I'd choose just about any BBK kit over that one so it doesn't mean much. I have Spoon calipers sitting here to be installed so I could be biased.
