Bay Area For Sale Items for Sale in the Bay Area. Only Member may post ads.
Mark this thread as Sold
FS: Full Built ATS 4.44 Differential and J's
Old Oct 15, 2006 | 11:27 AM
Brian_s2000's Avatar
Default FS: Full Built ATS 4.44 Differential and J's
For Sale
Complete and ready to install. Has Motul gear oil.
Fully built 03 differential with 5,630 miles with brand new ATS 4.44 final gears, new J's final drive bolts, new J's differential distance collar, three new OEM bearing, all new OEM seals, new OEM shims, all new OEM mounting / locking bolts and new OEM drains bolts. Used yellow box is included.
built by Rearend Speciality. Have the receipt.
Zero mileage after been rebuilt with the new gears.
all higher ratio gears then stock will whine including this one
I do not need your differential. You can just keep it as a spare or sell the differential out for around $400-600 and just make up the difference. I also have a AP2 spindle hub to whom that want to use this differential.
$1680 obo
Here is the break down and see how much you save in $$$
03 Differential (low miles) $600-800
ATS 4.44 - $980
J's distance - $110
J's final bolts - $75
OEM Bearings - $180
OEM bolts, oil seals, drain bolts, shims and washers -$40-$50
Yellow box - $110
Rearend installation service - $175
Honda VTM-4 differential oil 1gal - $18
You are already looking well over $2200 this differential
Old Oct 15, 2006 | 11:33 AM
will not bolt on to a 04 + model until you either change the spindle hub or retap the spindle hub.
Old Oct 15, 2006 | 12:06 PM
itS2Krazy's Avatar
brian. if you put it on for me......
Old Oct 15, 2006 | 12:46 PM
joey,
removing and installing is not that hard. Takes me about 1-1.5 to remove and install with air tools and a lift. For you should take you no more then an hour.
Old Oct 15, 2006 | 01:32 PM
f20c1 01s2k's Avatar
you have pm.
Old Oct 15, 2006 | 02:10 PM
Voodoo_S2K's Avatar
Easy install.
Old Oct 15, 2006 | 02:48 PM
spacecowboy's Avatar
Originally Posted by Brian_s2000,Oct 15 2006, 11:27 AM
This is just a GI
Complete and ready to go.
03 differential with 5,630 miles with brand new ATS 4.44 final gears, new J's final drive bolts, new J's differential collar, three new OEM bearing, all new OEM seals, new OEM shims, all new OEM mounting / locking bolts and new OEM drains bolts.
I do not need your rearend.
You putting my 4.77's on
Old Oct 15, 2006 | 03:45 PM
maybe. I need more torque to chase after your nsx
Old Oct 16, 2006 | 04:05 PM
Stephenopoly's Avatar
who's rearend do you need?....
Old Oct 17, 2006 | 02:06 PM
msmokie's Avatar
is your rear end up for grabs to brian? LOL.
you did it to yourself bro.
