02 sensor or replace header?
Old Oct 18, 2006 | 08:42 AM
bulldogs2k's Avatar
Default 02 sensor or replace header?
I got quoted for 340 dollars to get my 02 sensor fixed. Correct me if i'm wrong, but I can buy a used header (or megan header) and place an 02 simulator (or whatever its called) at around the same price range, right? I know I can buy a pepboys universal 02 sensor for 60 bucks....What would you guys do?
A
or with the header option.
Old Oct 18, 2006 | 08:56 AM
djpeak10's Avatar
you dont even need to get a universal one you can get a direct fit.
There is a direct fit one here for $8.95 Denso
http://replacement.autopartswarehouse.com/...0Sensor&dp=true
Old Oct 18, 2006 | 09:02 AM
Ek9's Avatar
Ek9
Banned
You can't use a simulator for the pre-cat O2 sensor. That's the one that tells the computer how to tune the mixture. That one's absolutely required if you run a factory ECU.
Old Oct 18, 2006 | 09:52 AM
MikeyCB's Avatar
That's a ridiculous price to install it though.
Old Oct 18, 2006 | 10:06 AM
djpeak10's Avatar
Believe it or not oem 02 sensors are that much, and yes it is rediculous
Old Oct 18, 2006 | 08:31 PM
bulldogs2k's Avatar
Is this for the precat 02 sensor? and will it be hard to replace? First time working on cars.
A
Old Oct 18, 2006 | 08:47 PM
chrisesteban's Avatar
i replaced mine its an easy job. just use the manual.
Old Oct 19, 2006 | 07:48 AM
djpeak10's Avatar
Yeah I did mine too. I would say go for it, because it gives you an oppurtunity to start doing your own maintenance and learning your car. Plus you dont have to pay a mechanic 60 bucks an hour.
[Side Note]I had no mechanic abbilitty before the S, then I made a decision to start doing all of my own work (for the most part) and it has been a really good learning experience, and now I enjoy it.
Old Oct 19, 2006 | 08:49 AM
Ek9's Avatar
Ek9
Banned
Most of the timer's there's NOTHING wrong with the O2 sensor. It's one of the most commonly replaced parts on the car even though there's nothing wrong with them.
O2 sensor code doesn't mean bad O2 sensor. There are potentially 50 other causes of an O2 sensor code. Unless you've screwed them up, they're normally good for 50-80K miles.
Old Oct 19, 2006 | 12:20 PM
bulldogs2k's Avatar
ya, i reset the cel code but the light came back on. i dont know if that means anything, but i will end up buying that 02 sensor. its less than 10 dollars so i have nothing to loose!
s2000maniac
Mar 29, 2025 09:09 AM
Subalahoo
Apr 6, 2009 02:48 PM
Black Sheep
May 4, 2006 04:12 PM
thetz99
Nov 21, 2005 04:16 AM
