Leaks into car from windows
Old Oct 28, 2006 | 09:39 AM
s2konroids's Avatar
Default Leaks into car from windows
Hi guys, so far i have lubed up the window seals, however this morning i got a soaked shoulder!. Its taking the piss now.
I have included a few pics here which show where it leaks from.
On the 1st pic, there is a small gap between where the roof folds in half and down into the back - there is small gap i presume this shouldnt be?. The leaks are at the A piller and fold, the same leaks happen at both windo sides.
Hope someone can help.
cheers
https://www.s2ki.com/forums/index.php?act=m...d=si&img=368761
https://www.s2ki.com/forums/index.php?act=m...d=si&img=368762
Old Oct 28, 2006 | 09:42 AM
wampa's Avatar
Hi Mine does the same in the same place!!
Old Oct 28, 2006 | 10:02 AM
wineboar's Avatar
I also get the leak from the fold in pic 1. I don't have a gap but certainly the 2 seals aren't pushed tight together.
This is the second set of seals that I have had on the car and am taking the car in for a service on Monday so will see what else they suggest. I think the issue on mine is finding out where the water actually enters the seal - somewhere up around where the hood joins the windscreen/door I think.
Not that useful for you at the moment but if the dealers come up with any other suggestions I'll let you know
Old Oct 28, 2006 | 10:03 AM
euan's Avatar
It could be your window height needs reset (if you'vre not already done it) - or maybe the seals have become unseated.
My 02 leaked a bit as per your first pic - I can't remember if I ever got it fixed though (the poor sod who bought my car may be able to tell you )
Old Oct 28, 2006 | 12:18 PM
s2konroids's Avatar
Cheers guys.
Wineboar : Hopefully your dealer can provide some info and you can pass it onto me.
Euan: Is it hard to do it my self? how much would a dealer charge?
cheers
Old Oct 29, 2006 | 01:44 AM
paullec's Avatar
I take it the rain water shoots out of the joint when you move if its been stationary for a while ? I found that the water enter the at the screen joint.
Old Oct 29, 2006 | 01:13 AM
s2konroids's Avatar
Exactly mate same here!, its results in me having a wet shoulder and knee! most annoying!
Old Oct 29, 2006 | 01:26 AM
paullec's Avatar
Never figured out how to stop it but if you park with the front uphill it doesnt do it :s
Old Oct 29, 2006 | 02:09 AM
s2konroids's Avatar
isnt really an option for me. I could wear a full waterproof!
Old Oct 29, 2006 | 03:25 AM
E4RTH WORM JIM's Avatar
I have the same leaks on my MY00, drivers side only. I found that if I put some vaseline between both seals it helps (Pic 2).
