*-*-*-* S2000 TSB's *-*-*-*
Old Nov 7, 2006 | 11:30 AM
SilentWhiteNoise's Avatar
Thumbs down *-*-*-* S2000 TSB's *-*-*-*
Here are the TSB's that a few of you asked for:
*NOTE*
There is no need to worry about TSB's. I just posted them because I had seen some interest in them. TSB's are for techs who are working on your car, not the average driver. If there is a problem that has occured often enough that it catches the Manufactures attention they will relase a TSB's that way the troubleshooting takes much less time and the problem is solved quicky. If there is a recall on the car it is also noted here. This information is usless to most people and unless you understand what it is used for and plan on fixing a problem yourself on your car you will have no use for this information. Unless you are a mechanic, you have no use for this thread.
***IF YOU DONT KNOW WHAT THIS INFORMATION IS OR WHAT IT IS USED FOR DONT WORRY ABOUT IT. THIS INFORMATION IS FOR MECHANICS***
MY2000
Number Date Title
88-023 04/19/2006 Electrical - Battery Test Procedure/Equipment
03-014 02/07/2006 Body - Convertible Top Cover Snap is Broken
02-065 10/28/2005 Body - Convertible Top Won't Work Properly
01-023 09/20/2005 Computers/Controls - Module/Control Unit Updating
01-037 07/05/2005 Body - Convertible Top Rattles/Windnoise
SN050600-011 06/01/2005 A/C - Heater Blows Cold Air, A/C Blows Warm Air
SN050508 05/01/2005 Exhaust System - Catalytic Converter Noise
SN050506 05/01/2005 Wind Noise - Simple Way To Replicate
SN050416 04/01/2005 Engine - Falters/No Power/Won't Rev Over 7000 RPM
SN050407 04/01/2005 A/T - Do Not Remove Torque Converter From Mainshaft
SN050418 04/01/2005 Body - Plastic Body Clip Removal Tips
SN050314 03/01/2005 A/T - Fixing Banjo Bolt Leaks
SN050316 03/01/2005 Engine Controls - Clearing DTC's
SN050311 03/01/2005 Windshield Wipers - Blade Care & Replacement
SN050202 02/01/2005 A/T - Avoiding Fluid Contamination
SN050215 02/01/2005 Audio System - Never Play CD's With Adhesive Labels
SN050105 01/01/2005 Suspension - Creak/Grunt From Rear At Low Speeds
SN050109 01/01/2005 Engine - Oil Recommendation GF-4 Standard
04-073 12/02/2004 Engine Controls - Hesitation on Hard Acceleration
SN040915 09/01/2004 Driver's Air Bag - Replace Torx Bolts Properly
SN040903 09/01/2004 Popping From Front Wheel Upper Control Arm Mount
00-064 08/03/2004 Body - Deformed Windshield Moulding
02-052 07/16/2004 Restraints - Occupant Detection Initialization
04-033 06/16/2004 Recall - Tail Light Side Marker Defect
NHTSA04V257000 06/01/2004 Recall 04V257000: Tail Light Replacement
SN040310 03/01/2004 ABS - Grunts When Doing A Self-Check
SN040308 03/01/2004 M/T - Grinding At Upshifts When Cold
98-011 02/20/2004 Keyless Entry - Remote Transmitter Information
04-009 02/17/2004 Computers/Controls - HIM Module Updating
SN040215 02/01/2004 ABS DTC 51 Or 53 - Diagnostic Tip
SN040211 02/01/2004 Speedo/Odometer Read Excessive Speed & Distance
SN040214 02/01/2004 Headlight Adjustments
SN040203 02/01/2004 Clutch Pedal Is Noisy or Feels Notchy
SN040111 01/01/2004 Engine Oil Recommendations
SN031107 11/01/2003 Blower (Heater) Motor Gets Hot and Blows A Fuse
SN031106 11/01/2003 Air Fresheners - Bad News For Paint Or Plastic
SN031007 10/01/2003 M/T - Hard To Shift Into 1st Gear, Grinds Into Reverse
03-062 09/16/2003 Interior - Seat Belts Slow to Retract
SN030915 09/01/2003 Suspension - Drifting & Pulling At Highway Speeds
SN030813 08/01/2003 Interior & Exterior Trim - Tool To Make Removal A Snap
98-018 07/22/2003 Drivetrain - Revised CV Joint Boot Band/Installation
SN030707 07/01/2003 Catalytic Converter - Rotten Egg Smell
00-088 06/03/2003 Brakes - Brake Disc Refinishing Guideline
SN030502 05/01/2003 Clearing DTCs & Setting ECM/PCM With The HDS
01-008 04/29/2003 Body - Driver Window Won't Go All The Way Down
00-049 04/29/2003 Antitheft System - Type 2 System Operation/Programming
SN030407 04/01/2003 DTC's P0133 & P0420 Set After Manual Trans R&R
03-023 04/01/2003 Body - Convertible Top Creaks/Pops/Rattles on Rough Road
03-020 03/29/2003 Engine Controls/Emissions - OBD II DTC's & Monitors
SN030205 02/01/2003 SRS - Indicator ON with No SRS DTC Set
03-001 01/28/2003 Emissions/Engine Controls - MIL ON/DTC P1457 (EVAP)
02-063 10/29/2002 Drivetrain - Vibration From Rear on Acceleration
02-046 07/30/2002 M/T - Difficult Reverse/5th Gear Selection
02-042 07/10/2002 Campaign - Spark Replacement
00-054 11/27/2001 M/T - Buzz/Rattle on Deceleration
00-055 06/12/2001 M/T - Grinds Shifting Into 2nd Gear at High RPMs
01-029 05/01/2001 Engine Controls - DTC Capture and Downloading
01-038 03/27/2001 Convertible Top Cover - Comes Loose
00-054 12/19/2000 Engine/Transmission - Buzzing on Deceleration
00-099 12/19/2000 Wiring Terminal - Repair Instructions
00-089 10/31/2000 Supplemental Restraint System - Inspection
00-083 10/31/2000 Heater Unit - Water Drips Onto Passenger's Carpet
00-078 10/17/2000 Recall - Seat Belt Retractor Sensor Replacement
NHTSA00V316000 10/04/2000 Recall 00V316000: Seat Belt Retractor Defective
00-048 09/26/2000 Convertible Top Rear Window Replacement - Manual Update
00-063 08/01/2000 Special Tool - Chassis EAR™, Diagnostic Tool
96-012 07/05/2000 A/C - System Performance Testing
00-057 07/05/2000 CD Player - Sound Cuts Out at High Volume
99-053 06/27/2000 Immobilizer Key - Key Code Duplicator
00-050 06/13/2000 Accessory Floor Mat - Anchor Moves From Side to Side
99-018 04/11/2000 Required Special Tools And Equipment,
00-037 04/01/2000 Convertible Top Rear Window - Creased, Cloudy, Scratched
00-015 03/14/2000 Audio Unit with CD Player/Changer - Error Codes
98-019 03/14/2000 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-032 03/07/2000 Paint Codes
00-020 02/04/2000 Recall - Convertible Top Cover
NHTSA00V016000 01/24/2000 Recall 00V016000: Convertible Top/Seat Belt Interference
97-015 12/07/1999 Service Publications - Availability & Ordering
98-031 11/09/1999 Aftermarket On Board Diagnostic (OBD) II Tester
99-030 05/04/1999 Recommended Materials
98-051 08/04/1998 Special Tool Loan Program
MY2001
Number Date Title
01-100 05/13/2005 M/T - Pops Out of 4th Gear
SN050206 02/01/2005 Engine Controls - DTC P0172
SN041204 12/01/2004 Fuel Filler Cap Adapter Available For Testing Emissions
01-001 01/16/2001 Paint - 2001 Paint Codes
MY2002
Number Date Title
04-002 02/13/2004 Fuel/Emissions - MIL ON/DTC P01456 (EVAP System)
SN040106 01/01/2004 Nose Mask Installation Tips
SN030802 08/01/2003 DTC P1456 - Evap System Diagnostic Aid
SN030508 05/01/2003 Audio Unit - Electronically Retrieving Serial Numbers
SN030510 05/01/2003 Audio Unit - Models Which Are Electronically Retrieval
03-012 02/18/2003 Interior - Center Console Lifts Up in the Back
02-013 05/07/2002 Paint - 2002 Paint Codes
MY2003
Number Date Title
SN041206 12/01/2004 Dashboard Switch Not Lit,? Replace Bulb, Not Switch
SN030418 04/01/2003 Odometer - Does It Rack Up Miles When Towed
MY2004
Number Date Title
01-077 04/19/2006 Ignition/Locks - Cutting Sidewinder-Type Keys
05-009 01/12/2006 M/T - Pops Out of 1st or 2nd Gear
03-065 09/23/2003 Paint - 2004 Paint Codes
MY2005
Number Date Title
05-001 01/28/2005 Paint - 2005 Paint Codes
MY2006
Number Date Title
NHTSA06V270000 07/25/2006 Recall 06V270000: Incorrect NHTSA Contact Information
MY2007
NONE RELEASED
Old Nov 7, 2006 | 11:40 AM
Mr. Eryozgatliyan's Avatar
Banned
Great info! thank you!
Old Nov 7, 2006 | 11:46 AM
Boofster's Avatar
So how do we look at these?
Old Nov 7, 2006 | 11:52 AM
s2kmaniac81's Avatar
What is the procedure for getting these taken care of? Are they considered warrenty issues or is at owners cost?
Old Nov 7, 2006 | 12:58 PM
FISH22's Avatar
what the heck is up with the incorrect NHTSA contact information for the 06???
Old Nov 7, 2006 | 01:31 PM
SC-SUZUKA's Avatar
Great tool. Thanks.
Old Nov 7, 2006 | 02:06 PM
pepperoni's Avatar
x2
Old Nov 7, 2006 | 02:18 PM
ottokrat's Avatar
Background: In case owners want to report problems to the government, the owner's manual has government contact information in it. Probably a legal requirement.
The NHTSA (National Highway Traffic Saftey Assocation?) contact information was printed wrong in the '06 Owner's Manual. The fix was that they sent out a postcard in the mail with the updated and correct contact information.
Obviously, there is no need to take the car in!
Old Nov 7, 2006 | 03:09 PM
m R g S r's Avatar
i dont get it what are these? sorry
Old Nov 7, 2006 | 03:20 PM
RadioZero's Avatar
this would be a great sticky. especially if it could be updated.
