4 months of ownership
Old Feb 8, 2007 | 08:51 AM
motogp1's Avatar
Default 4 months of ownership
as the weather has been crap today i worked from home,
went out and started the s about 1 hour ago,siting in car leting it warm up for a few mins first thing i get is .....eps light up on the dash (electric power stearing fault)
obviously no power stearing , i now can not get my lap top to connect via obd II connector and pcmscan software (which i have in the past)to find fault code.
not happy at the moment.
ok whinge over
Old Feb 8, 2007 | 08:52 AM
motogp1's Avatar
move me please ooooopppps
Dan Hale's Avatar
Sorry to hear this, hope it is all ok soon
Old Feb 8, 2007 | 09:12 AM
simonprelude's Avatar
Tried an ECU reset ??
Might just be the cold has triggered a sensor.
Old Feb 8, 2007 | 09:15 AM
Saxo Boy's Avatar
Were you manually holding higher than idle revs to expediate the warm up process? You should know that holding 3000rpm (ish) for an extended period causes the power steering to fail and the light relating to it to illuminate - it usually goes away after a few moments of driving. Failing that try and ecu reset
Old Feb 8, 2007 | 09:17 AM
motogp1's Avatar
i was about 2500rpm and i never new this why does it do that then.
thanks made me less pissed off
Old Feb 8, 2007 | 09:23 AM
Saxo Boy's Avatar
I can't remember why it does it? It happened to me once, I posted up and I *think* it was AE that advised me of the cause. It should be fine though - no harm done
Old Feb 8, 2007 | 09:31 AM
motogp1's Avatar
sounds like ive done exactly the same.........ill remember that one for the future
id better go and put the front door back on i think i kicked it a bit to hard .oops
cheers
Old Feb 8, 2007 | 09:35 AM
AquilaEagle's Avatar
Administrator
Yup happened to me once, just the cold weather, seems to be when you rev it up a bit to warm it up from cold, EPS doesnt like it?!
Old Feb 8, 2007 | 09:46 AM
motogp1's Avatar
