Sputtering, stalling, lean conditions
Old Apr 7, 2007 | 10:30 AM
ShocK's Avatar
Default Sputtering, stalling, lean conditions
Read thoroughly please, I have checked a lot myself, I'm a mechanic but I dont have diagnostic tools. So my car started to kinda hesitate a couple weeks ago when I'd pull off from a dead stop. Then the next week it started misfiring when I would pull off from a dead stop then at low throttle inputs it would completely shut down injectors and would barely pull itself, my wideband reading ---- which is off the charts lean. I checked my VAFC harness for problems and found nothing, I even removed it and the car was still acting all crazy. I ended up unplugging the primary O2 and then the car ran fine, like normal actually, but it was idling at 1500-2000 rpms which is rediculously annoying with my stupid loud exhaust. I got an O2 from Billman and plugged it in and reset the ECU. The same problem comes back. It actually seems to have gotten worse, stalled a couple times when I tried to take off, just barely giving it throttle. My wideband is reading 15:1+ a/f ratios under full throttle which is piston melting a/f so I really need some advice. There is no CEL. Any suggestions? This is pissin me off, the dragon is next weekend!
Old Apr 7, 2007 | 11:19 AM
jyeung528's Avatar
i would sure like to know as well...please keep us tuned in.
Old Apr 7, 2007 | 11:24 AM
ShocK's Avatar
Downloading manual from hondahookup as we speak.
Old Apr 7, 2007 | 12:36 PM
ricosuave's Avatar
have you tried disconnecting the battery overnight?
Old Apr 7, 2007 | 03:12 PM
ShocK's Avatar
No, but I dont think thats necessary, unless there's something I don't know about. I had a code from where I disconnected my O2 so I could drive it home then disconnected it for like 20 mins and the code was gone.
Old Apr 7, 2007 | 03:54 PM
clawhammer's Avatar
Do you have a cat or a test-pipe?
If you still have a cat, try unbolting it and taking the car for a spin. See how the car drives then.
Old Apr 7, 2007 | 04:45 PM
ShocK's Avatar
I have a full exhuast with test pipe arriving wednesday. However I found that if I floor it and release the pedal slowly I have a flat spot in the pedal, going to find a scanner and see if I can read the voltage outputs. would the TPS cause this kind of running condition? Very strange... still diagnosing, frustrating!
Old Apr 10, 2007 | 08:51 PM
ShocK's Avatar
What you guys think about the map sensnor?
Old Apr 11, 2007 | 02:45 AM
clawhammer's Avatar
Have you tried a map whack? Search the forum for it and try it.
Old Apr 11, 2007 | 10:40 AM
s2krey's Avatar
I had this slugish before from a dead stop and trying to move again.
Might be very bad heat soak or just try a map whack.
GL, keep us updated.
