Photos of speaker installs?
Old Feb 21, 2002 | 06:11 AM
sklavo's Avatar
Default Photos of speaker installs?
So I'm looking for some photos of KAPPA PERFECT 5.1 and 6.1 installs. Specifically the 6.1s... How did you get them to fit??
Here's an install of Eclipse: http://www.windspear.com/jordan/S2000.htm . They helped, but still are far from sounding correct.
Old Feb 21, 2002 | 07:41 AM
jzr's Avatar
jzr
The 6.1s fit fine with an amply-hacked speaker basket:
But I ended up making a 3/4" MDF ring backed by a fiberglassed foam XTC baffle, which helps the fronts in bass reproduction:
Old Feb 21, 2002 | 07:50 AM
sklavo's Avatar
What did you end up doing to the door panels?
Old Feb 21, 2002 | 08:09 AM
jzr's Avatar
jzr
Um, I put them back on...
Old Feb 21, 2002 | 08:21 AM
sklavo's Avatar
Sorry, I should have been more concice. I take it you mounted the crossover on the door panel? And how much did you end up hacking the speaker mount that was there.
I'm concerned about decreasing the stiffness of the door panel and having it vibrate. It wasn't quite built for a set of "real" speakers and what they can drive.
Old Feb 21, 2002 | 09:29 AM
jzr's Avatar
jzr
Yep, the crossover is in the mysterious "black box" in the door panel. The speaker mount was basically entirely hacked away, leaving only a "ring" of plastic to mount the speaker to, which was then mounted to the door.
The plastic ring actually worked just fine. I too was worried about the door rattling, hence all the dynamat. But in retrospect it probably wasn't necessary, especially as I have the fronts crossed over relatively high (~100hz).
Old Feb 21, 2002 | 12:56 PM
98honda's Avatar
what is a fiberglassed foam XTC baffle.
My understanding was that a baffle was the component that your speaker is mounted to, ie, the MDF ring.
I also wouldnt worry too much about vibration, its not like the S2K is a quiet cabin to begin with.
Old Feb 21, 2002 | 01:19 PM
jzr's Avatar
jzr
I guess "basket" is a better word than baffle. It's a piece of foam that is treated with fiberglass resin for stiffness, which effectively seals off the airspace behind the speaker. This protects the speaker, and helps somewhat with bass output. It also helps keep the side mirrors from shaking too much.
Old Feb 21, 2002 | 08:35 PM
98honda's Avatar
shaking side mirrors is a problem
where did you get those? Creating something of an enclosure is a DEFINATE plus.
m1sterlaw
Jun 13, 2010 06:22 PM
travanx
Sep 19, 2009 04:40 AM
ExeC
Jan 7, 2008 02:17 PM
street_ruler
Oct 7, 2007 04:06 PM
ScoS2k
Dec 21, 2001 04:39 PM
