New Discs
There's no significant difference between oem honda, brakes int bremtech discs and ebc plains. The are visually indestiguishable from each other and there will be no performance benefit from any of them.
You won't notice any braking improvement from the turbo grooves either unless you have glazing problems with your pads.
I doubt you'll get a unanimous verdict on here, each to their own and at the end of the day you pays your money and you take your choice. It's a bit like asking "What colour car should I buy".
You might want to flick through:
https://www.s2ki.com/forums/index.php?showtopic=470155
For me personally I ended up with EBC Turbogroove, Ferodo DS2500 pads (which do generally get a
), braided hoses (NBM Woolford) and Millers Racing brake fluid, all from BalanceMotorsport: http://www.balancemotorsport.co.uk
Julian there is a top guy and always willing to give advice if you give him a call, mention the forum he might give you a discount.
My setup worked well at Rockingham (a circuit that's hard on the brakes), although being a track-day newbie I probably wasn't being that aggressive. However, personally I'm happy with the setup and will probably stick with it for Donington.
Dembo recently cracked an EBC Turbogroove at Angelsey (but he'd given them some welly over a period of time), but I think he still bought another set.
Good luck with whatever choice you end up making.
Thanks, jq. I'm quite happy with the OEM brake set-up. I'm not looking to upgrade the discs, just don't want to get cheap ones that would be a false economy i.e. cheap and rubbish not cheap and good value.
91rtstealth
Sep 10, 2013 09:43 PM
dthondatune
Oct 11, 2007 02:48 PM
