Mark this thread as Sold
J's Engine Torque Damper
Old Jul 9, 2007 | 05:37 PM
Ustemuf's Avatar
Default J's Engine Torque Damper
I bought this from SOCAL member NSX2FAST but didn't use it because I ended up purchasing a comptech supercharger that uses the same bracket. I think I paid a bit over $200 something.
I'm just trying to get it out of my garage $125 shipped.
wysiswyg - slight scuff on other side not pictured. does not affect in anyway, cannot see when installed - was shipped to me that way without my prior knowledge due to nsx2fast shadiness.
Old Jul 9, 2007 | 06:03 PM
WashabiS2K's Avatar
bump for kurt
Old Jul 9, 2007 | 08:22 PM
Monkeyboi's Avatar
Any mods, like the NRG to install this ?
Old Jul 9, 2007 | 08:26 PM
NFRS2kSi's Avatar
^^ it should bolt right in, but you'll need to either take off the heat shield, drill the a hole or replace w/ j's or spoon heatshield that has pre-hole.
ps. you'll need to cut the fuse bracket. i end up using piler to pull it off.
Old Jul 9, 2007 | 08:42 PM
kaansahbaz's Avatar
i ll take it if there is no problem or an issue with the damper
