Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Rotational Noise!
Old Nov 3, 2007 | 05:49 PM
s2korea's Avatar
Thumbs down Rotational Noise!
Description: rotational noise that's coming from the front, or the transmission.
I did some tests to locate the noise
1. The noise's pitch increases with the car's speed.(direct relationship)
2. Sounded like Hubs/bearing, so replaced both rear sides hub/bearings(only rear)
3. The sound was still there, so replaced rear diff(today)
4. Sound still there with new diff. Mechanic told me it could be the transmission.
When stationary, I turn on the engine, i hear some grinding sound. When i press on the clutch pedal, the grinding sound goes away. When clutch pedal is released, the grinding sound returns.
5. So as I was coming back from the shop, I was going 60km/h, I turned off the engine to see if it was the transmission. Cruising at 60km/h down to 40km/h with engine off, sound is still there.
WHERE IS THIS SOUND COMING FROM????!??!!?!??!?!G;HFGA;SLKDFHA;SLKDFJ
Old Nov 3, 2007 | 06:08 PM
Tugz_S2K's Avatar
Banned
Wow,....u must have the worst luck with this car. Sounds like its beat....
Old Nov 3, 2007 | 08:15 PM
Jasonoff's Avatar
Banned
Throw out bearing and it's pretty much normal. Stop nit picking every little sound. This is a noisy car like I told you.
If every little tiny sound is going to bother you I would suggest another car
BTW is that nasty sound when turning left gone now with the new dif?
Old Nov 3, 2007 | 08:28 PM
s2korea's Avatar
Yap, that's completely gone. I got a whole rear end done...i got a good deal off someone and it was easier to install the entire part from an 05 since i wanted to fix the CV vibration as well.
I think the rotational noise has to be from the front of the car... transmission seems to be ok since it makes this sound when the engine's off anyways...
Old Nov 4, 2007 | 08:25 AM
Jasonoff's Avatar
Banned
It wouldn't explain it going away when you push the clutch pedal to the floor.
It's not coming from the front of the car. It's the TO bearing and it's normal.
I drove your car and it's NOT a loud noise lol.
Old Nov 4, 2007 | 10:24 AM
s2korea's Avatar
https://www.s2ki.com/forums/index.php?showtopic=540137
Someone agrees that it might be the clutch throw out bearing..
Jay.. how hard is it to change them?
Old Nov 4, 2007 | 10:30 AM
s2korea's Avatar
In additions to 5.
6. When rolling with engine turned off, I hear the rotational sound, i press on the clutch, i still hear the rotational sound.
Old Nov 4, 2007 | 03:31 PM
Jasonoff's Avatar
Banned
Dude.. just leave it.. there's nothing wrong it's just noisy.
You have to remove the transmission to change that bearing. Just wait until you need a new clutch.
Old Nov 4, 2007 | 05:27 PM
s2korea's Avatar
Nice..i found something...
https://www.s2ki.com/forums/index.php?showtopic=409603
It's the whining sound i get... i don't know if the rotational sound is related to this..but seems like my transmission rebuild is coming up.
Old Nov 5, 2007 | 05:35 AM
Jasonoff's Avatar
Banned
The sound of those worn bearings wouldn't go away when you push your clutch pedal down as you described.
