My06+ w/Test Pipe - Most Miles wo/ CEL
What's the most miles/time you've been without a CEL while running a TP?
Give your setup (header, exhuast, tp, type of fix, ect.)
i just installed the invidia 70mm tp w/ built-in fix on an otherwise all stock 2007 and got a cel after only 40 miles, added a one piece exteral fix packed with steel wool and made it 200+ miles so far... What your experince?
I had a Megan TP with 2 defoulers screwed together and I had 4000+ miles with no CEL. I got it here http://www.invisions2k.com/product-p/celfix.htm
Now on my T1R TP I had it once when it got cooler but after that 3000 miles CEL free.
Miles are irrelevant...
Once the monitor is run for the cat, either the CEL will come on or stay off.
If the monitor completes at 40 miles, and does not store a pending P0420, you can go a million miles.
This may be good reference for MY06 Owners
Did the steel wool trick on top of a defouler bought from e-autosports. So far about 70 miles with no CEL. I keep thinking with the given temperatures inside the testpipe, I would think the wool would either melt or ignite on fire since its EXTREMELY ignitable.
My set up: Berk testpipe, stock header, full greddy ti-c exhaust.
