Can anyone comment on Brake Bleeders?
Old Feb 19, 2008 | 09:43 AM
CKit's Avatar
Default Can anyone comment on Brake Bleeders?
Hello
From what I've been reading, the solo-bleeders leak less than the speed-bleeders. I also hear that the correct size is M10x1.25 (~$11 each online). I didn't see them on Ricks2k site anymore.
I'm planning on a dozen auto-x this year and maybe 3-4 HPDE at tracks. I have Carbotech AX6 pads and Mich Pilot Sport Cups. I know that they're all compromise options, but until I get a trailer / more free time, I'm going with a mildly upgraded tire / brake setup.
I've been reading up on the FAQs and plan on changing pads / wheels from OEM / OEM to the AX6 / MPSCs in my garage in between events.
My brake fluid is old and dirty.
So my question is:
For this kind of use, is changing the fluid 2-3 times per year sufficient? DOT 4. It'd be mainly just me and the jack stands, but I could enlist my wife to pump the brake pedal if additional help was needed.
Any advice on a convenient setup that limits me spilling brake fluid all over myself and the garage? Cost is not really a concern (but no $2000 automatic mechanic grade equipment, please).
I've heard:
1. Stock bleeder screws, empty coke bottles, turkey baster
2. Solo-bleeder screws, empty coke bottles
3. Some combination of hydraulic / "pump" type systems.
Any suggestions for my planned usage?
Thanks!
--CKit
Old Feb 19, 2008 | 11:00 AM
Hobbs5313's Avatar
I haven't used solo-bleeders, but I have speed bleeders on my car. They're very convenient and easy to use. I would highly recommend them. You don't need another person to flush or bleed your brake fluid.
When I first installed speed bleeders on my car, one of them leaked right away. The trick to making sure speed bleeders don't leak is to buy a bottle of their sealant ($10) and apply a liberal coat on the treads before you install them. After I did that, I haven't had any leaks since.
As for changing or flushing the brake fluid, I think 2-3 times a year should be sufficient with the number of autoX and track events that you're planning for this year. I would try to schedule a fluid flush to take place before a track event. If you don't flush the brake fluid before a track event, you should bleed it a bit to at least get some "fresh" fluid in the calipers. AutoX events don't seem to tax the brake fluids much.
Just for reference, I did 16 autoX events and 13 track days last year, and I flushed the fluid four times and bled it several times.
Old Feb 19, 2008 | 01:57 PM
Vitt's Avatar
I used the speed bleeders on an Integra for about 6 years. They are still on the car and so far I have had no problems with them. The main thing to remember is don't over-tighten them because that's what causes leaks.
I recently bought solo-bleeds for the S2000 because I also read that they are less prone to leaks. Unfortunately they sent me the wrong size thread when I first bought them. Then the store owner gave me a couple different sizes to try out, and one of them was the correct one. That one is installed on the right front of the car and I have had no leaks. I am waiting for the other 3 to come in.
Make sure you get the size correct, because this shop owner told me that EARLS have the incorrect size for the S in their catalog, so they package the wrong items. That's why it's taken so long to get mine correct. If you want to talk to him, here is the website: http://www.anplumbing.com
When you ask about the S2000 specifically, he should be familiar with it since he's been trying to get me the correct size.
Old Feb 19, 2008 | 02:36 PM
alejo's Avatar
My speed-bleaders have not leaked yet...
Old Feb 20, 2008 | 11:23 PM
ddess's Avatar
what size speed bleeders? the website I found does not have them for the S.
Old Feb 21, 2008 | 04:23 PM
CKit's Avatar
the solo bleeders I ordered were metric 10 x 1.25 x 33.
Old Feb 21, 2008 | 04:39 PM
dans2k's Avatar
I just called Earl's and they said out of stock til 2 weeks.
Old Feb 21, 2008 | 10:24 PM
Ludedude's Avatar
Administrator
I had speed bleeders on the Miata. Used them all the time as the car was tracked several times a month. They never leaked but they always made me nervous.
Old Feb 22, 2008 | 08:08 PM
rlaifatt's Avatar
Speedbleeders
Old Feb 24, 2008 | 05:38 PM
9kI4's Avatar
another happy speedbleeders user here
