Sponsored by:
Sponsored by:
Rate the condition of this tire!
Old Mar 6, 2008 | 06:35 PM
DongTran's Avatar
Default Rate the condition of this tire!
How would you rate the condition of this tire and why? What percentage of tread would you consider to be remaining? This is a 235/40R17 Toyo RA1.
I recently purchased this as part of a complete set from someone. Just wanted to gather some unbiased opinions just to make sure I'm not just talking out of my ass.
Thanks.
EDIT:
I wanted to gather opinions before I posted another angle of the dangle:
On Thu, Mar 6, 2008 at 11:18 AM, ScienceofSpeed Info <info@scienceofspeed.com> wrote:
> hi Dong --
> We sent you the set with the most tread. The fronts have typical wear on
> the outside shoulder from not enough camber (not toe). However, the
> tread on the complete tire is signficantly more than the 50% advertised
> in the ad.
Old Mar 6, 2008 | 06:44 PM
globallyoff's Avatar
Here that tire is going to cost you $2 so it can go to the dumpground and hopefully be recycled. I'd rate it less than 0% because it's bald below the treadwear bars.
Old Mar 6, 2008 | 07:15 PM
BB_S2K's Avatar
Those tires are dead - at or past all wear bars.
Old Mar 6, 2008 | 07:20 PM
CaptainMike's Avatar
0%
Old Mar 6, 2008 | 08:54 PM
Asura's Avatar
Whomever sold those to you
They are either worn from too much toe or too much camber. Either way they are done.
I can't tell if the top of the tire is the inside or outside, not like it matters though.
Old Mar 6, 2008 | 09:07 PM
Faber's Avatar
Are those Kumho R compound tires?
Old Mar 6, 2008 | 09:26 PM
DongTran's Avatar
They are Toyo RA1s.
Open to more opinions before I share my own.
Old Mar 6, 2008 | 09:38 PM
tomcrane's Avatar
those tires are shot .. the uneven wear is ridicilous ... and obvis you can see they are worn down to the bars on that one side
those = garbage
this dosent have anything to do with the wheels you bought from CHRIS@SOS does it ? i was looking at your old posts and it appears that you bought some volks from him... did he misrepresent the tires ?
Old Mar 6, 2008 | 09:51 PM
Chris_Lum's Avatar
might be good to ask this in the competition forum, since the RA1 is used a lot in competition. If a street tire looked like that, i'd say it's done for sure, but i'm not so quick to say that with an RA1. I'm no expert though, and never owned a set of R comps....best getting an opinion from someone who's used them a lot.
Old Mar 6, 2008 | 10:09 PM
tomcrane's Avatar
it looks like i was right .. you added that last pic of the ce's there...
i looked at the sellers thread and all the info was erased...
what did you believe the condition of the tires to be when you purchased them ?
