Need help with windscreen LED wiring.
Old Mar 6, 2008 | 07:48 PM
Sarek's Avatar
Default Need help with windscreen LED wiring.
I just installed MacGyver's LED windscreen lights (LEDs)
All I have left to do is wire it up. Unfortunately, Dan (Macgyver) hasn't responded yet to my email. I thought someone here might know, as I know nothing of wires and car audio/electronics...
here are the pics:
there are 6 wires:
white
black (I'm assuming this is ground)
red
blue
green
yellow
is there a way to "test" the wires to see what they do without messing up anything?
here's an old thread an old thread about it (the kit has since been updated and the instructions are now obsolete)
thanks in advance!
Paul
Old Mar 7, 2008 | 02:31 AM
TJ S 2K's Avatar
Red +12v
Black -/Ground
Yellow Reverse Light +
Green Brake Light +
White Turn Signal +
Blue Color Selection
I hooked red to parking lights so it turns off with lights.
Old Mar 7, 2008 | 11:16 AM
Sarek's Avatar
Originally Posted by TJ S 2K,Mar 7 2008, 03:31 AM
Red +12v
Black -/Ground
Green Brake Light +
White Turn Signal +
perfect! That's exactly what I needed to know! Thank you very much!
Paul
Old Mar 7, 2008 | 11:21 AM
Sarek's Avatar
TJS2K,
ok, I understand the red and black...
But can I connect the brake light function AND the reverse function and be able to use both features?
Or am i limited to only one feature?
Thanks again!
Old Mar 7, 2008 | 12:21 PM
TJ S 2K's Avatar
Use any or all I used a DIP switch so I can turn any of the functions on or off. Didn't know if I would like amber turn signal flash etc.
Old Mar 7, 2008 | 01:00 PM
Sarek's Avatar
thanks again, the dip switches are a great idea!
Old Mar 7, 2008 | 02:25 PM
HS2K007's Avatar
how did you get the assembly apart
Old Mar 9, 2008 | 11:19 AM
Moddiction's Avatar
Hey post some pics if you can when installed and wired up. -- Ry.
Old Mar 9, 2008 | 02:36 PM
Sarek's Avatar
http://www.ricks2k.com/info/instructions/w...tallation02.pdf
Old Mar 9, 2008 | 02:39 PM
Sarek's Avatar
hopefully will get some time this week!
