leaking boot
Old Mar 25, 2008 | 01:36 AM
tomkbucks's Avatar
Default leaking boot
just lifted the plastic tray out and its full of water at the bottom , any common points the boot leaks from ??
Old Mar 25, 2008 | 02:17 AM
mpease0603's Avatar
Has your roof ever been removed or replaced & do you get excess condensation on the inside of your windscreen?
If so, your roof's probably leaking . I had the same problem when my roof was changed under warranty. Water was coming in just behind the driver's side boot hinge where it pooled, ran down towards the rear lights then ran down into the well. I think it was the roof gutter (plastic bit that runs along where the roof meets the car on the outside) that hadn't been fitted correctly. I discovered it by running a hose over the roof and looking in the boot. Honda refitted it and the problem went away.
Another cause could be water coming in through the air vent, check the following thread...
https://www.s2ki.com/forums/index.php?showtopic=465581
...I just sealed mine inside the boot with plumbers mait just in case.
Once you sort it out, keep your eye out for rust coming through where the water's been sat.
Old Mar 25, 2008 | 02:19 AM
Vixen's Avatar
I sealed the air vent and it didn't solve the problem unfortunately.
I currently have no lining in my boot. It doesn't appear to leak even when it is tipping down. Only when I drive somewhere. Very odd.
tomkbucks's Avatar
nope no new roof or water in the roof , i had washed it so a lot of water had been on the hood / back ... arse no idea how i will find were its comming in ...
Old Mar 25, 2008 | 02:24 AM
mpease0603's Avatar
Was the water in the boot soapy, ie. the water from washing your car, or was it clear, ie. rain water?
Old Mar 25, 2008 | 02:26 AM
tomkbucks's Avatar
could not tell it was just water.. things were damp to annoyingly i had my overnight bad in there, its not soaking.. so need to clean it out, dry it and see with the use of a hose if i can work out where its leaking...
Old Mar 25, 2008 | 02:35 AM
mpease0603's Avatar
When you take out the bottom piece of lining check the underside to see if the upper parts are wet too or just the well part. This could help indicate where the water's coming from. Mine was wet where it was pooling behind the lights so this helped to narrow it down.
Another tip...if you line the boot with old newspaper it will make the leak easier to spot.
Old Mar 25, 2008 | 02:43 AM
tomkbucks's Avatar
cheers will try it ! annoying though... did not realise the sk2 was prone to 'leaks' suppose worst comes to worst i cant keep anything in the boot !
Old Mar 25, 2008 | 02:48 AM
j8mie's Avatar
It does seem odd that some cars leak and others don't. I would take the rear bumper off and put some silicone sealant around that air vent. It didn't help Vixen, but it might help you. It's been identified as cause of leaks, so I wouldn't ignore.
Old Mar 25, 2008 | 02:53 AM
tomkbucks's Avatar
how can it leak though a vent in the bumper though ?
