Koni 'sleeve' with Ground Controls
Old Mar 26, 2008 | 07:18 PM
saaboteur's Avatar
Default Koni 'sleeve' with Ground Controls
Bought second hand a set of Konis with Ground Controls, and now I also have brand new top mounts from Ground Control too.
But I'm missing what Ground Control calls a 'sleeve', and what's described in the factory service manual as 'damper mounting collar'.
Question - can I use the stock sleeve / damper mounting collar with the Konis? I understand the OE shaft diameter is 10mm, but the Koni is 12mm. If that's the case, perhaps the stock sleeve / damper mounting collars can be modified to fit?
Otherwise, anyone know if it's possible to purchase the sleeve / damper mounting collars on their own?
Old Mar 26, 2008 | 07:33 PM
harrrrry's Avatar
You'll want the sleeve since it'll let you adjust the height
Old Mar 26, 2008 | 07:35 PM
saaboteur's Avatar
I do have the threaded sleeve and collar, I'm talking about a smaller metal sleeve that I believe goes inside the top mount's upper bushing. Any ideas?
Old Mar 26, 2008 | 07:49 PM
nearwater4me's Avatar
Koni yellow shocks come with their own sleeves.
Bump stops and other metal bushings should be modified(drilled out) to work w/ the Koni shocks.
If you go into the DIY sticky thread, there's a link to the Koni/Eibach installation.
It'll help you a lot.
Good luck.
Dan
Old Mar 26, 2008 | 10:06 PM
saaboteur's Avatar
Thanks, I'll check it out!
yourboysoap
May 13, 2017 09:16 AM
Chris@NLM
786
Dec 28, 2015 10:04 PM
J.T
Sep 17, 2009 07:33 PM
