Buying a used S2000--what to look out for?
Old Mar 29, 2008 | 05:37 PM
5abi's Avatar
Default Buying a used S2000--what to look out for?
hi guys. i am looking to buy a 2000-2003 s2000 for less then $15k. just wondering what stuff to look out for when looking at some? what would u consider too high mileage? should i be taking it to honda and getting an inspection? do compression tests? thanks for the help in advance
Old Mar 29, 2008 | 05:43 PM
detonator2x's Avatar
I think 10-12k miles a year is about average for most vehicles.
Old Mar 29, 2008 | 05:44 PM
hguerrero's Avatar
get service records...miles are not as important as proper maintenance....
can't hurt to get it inspected and a compression test...a little money up front might save you thousands later...
Old Mar 29, 2008 | 07:17 PM
__redruM's Avatar
Check for tire wear, including the inside edge of the front tires. Check the clutch for noise and/or wear. It would be nice to check the valve spring retainers, but most owners would hesitate to let you pull the valve cover.
Most importantly, check the insurance rates. The biggest surprise I had buying the S2000 is how much it bumped my insurance cost. That and VTEC.
Old Mar 29, 2008 | 07:24 PM
s2k_man's Avatar
Make sure the top is not torn or worn down where the top folds down.
I am also in the market for an ap1 s for under 15k : )
I personally am not considering anything over 60k miles. And would like to buy the S from old folks that have treated their car well.
Good luck with your search!
Old Mar 29, 2008 | 09:01 PM
One of my buddies has an uncle who is about to sell his 04. It's the colour combo I like too
Old Mar 30, 2008 | 03:40 AM
clag's Avatar
Few suggestions
- drive or at least ride in another S, the car is loud in some ways, you need to know what passes for normal
- check the top inside and out for wear
- check every body panel for a VIN sticker, make sure they match (no replaced parts), the engine may have a different VIN, this is not unusual
- check under front and rear for curb rash, one I looked at actually had rear sub-frame damage from someone backing it onto a curb
- check A-arm brackets https://www.s2ki.com/forums/index.php?showt...0&#entry1446324
- check oil level and condition and for any leaks
- listen on startup, ticking and light clatter is usually valvetrain or injectors-normal, knocking could be a scuffed bore-not normal
- make sure clutch holds strong and grabs early
- shifts without grinds, particularly 1-2
- goes into 5-6 easily when warm, transmission can be a little stiff for first 15-30 min.
- do gentle figure eights in open lot to check diff for clunking
- getting a compression and leakdown check is a very good idea, if the owner will allow for it
The big three $$ are engine, trans, diff. These are some things you can do to check them.
little things that can tell you what kind of owner
- matching set of tires front and rear, appropriate size
- casually ask them how long the OEM tires lasted, I got about 18k out of the fronts,12k out of the rear
- do they do their own maintenance, what intervals, what fluids (most common: trans- Honda MTF or GM Synchromesh, diff - LE607,Mobil 1 Gear), is the oil filter Honda OEM
- condition of brake and clutch fluid (dark is bad, light or almost clear is good)
- condition of top seals (lightly greased)
- ask them about the power steering fluid (little joke, the S has electric assist, their answer might tell you a few things)
things I would do as soon as I bring it home
- pull valve cover and inspect retainers
- maybe send an oil sample off to Blackstone for an oil analysis
- have that compression test if you have not yet
- get a good alignment on it
- change all fluids and filters unless you have no doubt on their condition
- check oil often, some years drink a bit
- autocross!!
Good luck.
Old Mar 30, 2008 | 08:00 AM
Very good advice Clag
Old Mar 30, 2008 | 09:14 AM
EVAN&MONICA's Avatar
I agree get an insurance quote first but my insurance went down almost $50 a month I came from a 94 civic
Old Mar 30, 2008 | 05:52 PM
unclejemima's Avatar
good advice clag!
-mark
