Jacksonville 1st Coast S2000 Owners
JAX Mod Day 2008!
Old Jul 27, 2008 | 06:57 PM
zbrewha863's Avatar
Default JAX Mod Day 2008!
[Negcamber editing starts here]
We have a date and location! Tim (timt976) has offered to host. It must be a new house since it's not even on the map yet. So we can pop his garage's cherry. Besides...what's a garage or drive way without some oil stains, right?
Where:
Tim's house
6463 Crimson Leaf Ln
Jacksonville, FL 32244
This is off of Skyler Jean Dr (MAP)
When: Sunday 9/7 starting at 10am (I'll bring Panera bagels & coffee if someone brings donuts...mmm...donuts)
Work will be done first come first serve...tie breakers resolved by the list below.
[Negcamber editing ends here]
We're setting up a mod day -- Josh is going to lend a hand with the hard stuff, and we can all do the rest. Josh won't be available for at least a couple weeks, but I figure if we start this now, everyone will have time to plan. I'm buying a couple cases of beer (feel free to suggest what you want, I'll probably get two different beers). So far, here's what we have:
Me (zbrewha863)
yarbrough
ZeroPsi
jesusphish
MIAMI4QUAD
SBlueS2k
DocB04
s2kyo
skipdodoubleq
flipnrr
s2kmayhem
timt976
JustinsanE
RedS13
Josh and I each have low-profile jacks and two jack stands apiece, so we can work on at least two cars at once.
I'm also installing a set of Mugen cooling mods and Samco radiator hoses, but I can do that stuff myself (esp. since I'm going to drain the coolant for the IMG install).
Feel free to add your name to the list!
Old Jul 28, 2008 | 03:29 AM
yarbrough's Avatar
You can take me off the list of IMG install. I got tired of it in my trunk and sold it this past weekend.
Old Jul 28, 2008 | 04:43 AM
zbrewha863's Avatar
Yeah, I'm kind of in a war of attrition with mine, too
Old Jul 28, 2008 | 04:58 AM
jphish's Avatar
Until we confirm a date I am a maybe.
Old Jul 28, 2008 | 10:37 AM
JustinsanE's Avatar
Too bad this happens when I am leaving. I would have loved to do both of these.....
Old Jul 28, 2008 | 02:17 PM
TurboCongo's Avatar
Im down... i might have a nitrous kit to install! Anyone good with wiring?! and whats up with eveyone doing a Valve adj?
Old Jul 28, 2008 | 02:25 PM
dc2-2-ap1's Avatar
i am alright with wiring but i have no clue about nitrous systems. valve adjustments are just regular maintenance- well it is with me, i usually do it every 10,000 miles
Old Jul 28, 2008 | 05:42 PM
zbrewha863's Avatar
I don't touch nitrous, it scares me and I hate it.
Are you going w/ wet, dry, or direct port? A dry shot is probably one of the most simple things to install, a wet kit is a little more complicated (but you can do it yourself if you have the right supplies and experience), and for a direct port setup you should get a pro to do it.
Old Jul 28, 2008 | 05:50 PM
TurboCongo's Avatar
Its a direct port wet, but its a EFI so it should just fit in with the injectors right?! i just want to get it hooked up before i go get it tuned. so i save a little bit before i let stage 6 get there hands on it!
Old Jul 28, 2008 | 07:03 PM
zbrewha863's Avatar
Without knowing the specifics of your kit, it's hard to tell, but I have seen direct port kits that include injectors where the nitrous lines plug into special injectors. Hooking up the hoses beforehand seems like a good idea, just don't turn it on before it's tuned ... especially since you're using what I assume is a big shot of nitrous (since it's a direct port kit)
