Mark this thread as Sold
GB Drive shaft spacers
Why do you need drive shaft spacers ?
The original drive shafts of the S2000 are designed at the stock ride height so when the car is lowered with coil springs or coil-over suspension then the drive shafts will be stretched about 10mm each side. This will incur a lot of stress to the drive shaft. As a result, the drive shaft will wear down over a period of time.
J's Racing and the likes make these kits for around $200, but S2KUK is able to source a high quality kit for around
Originally Posted by Hypersonik,Aug 6 2008, 07:11 PM
Do they not do the split ones?
Just saying, split ones will take you a LOT less time to fit.
Originally Posted by LTB,Aug 6 2008, 07:14 PM
I have been informed that these will take about an hour to fit if you have access to a lift/ramps.
That means dissassembling the rear hub.
ok, not complex, but time consuming.
That and not many people have a lift/ramp.
I would say, cut them in half, but I know to many peole would get freaked out by that idea....
Originally Posted by Hypersonik,Aug 6 2008, 08:21 PM
Just letting you know that the shaft will have to come out.
