Mark this thread as Sold
FS: Barry's Garage Sale
Most of these parts are from a 04 that was totaled due to frame damage, unless otherwise noted.
the first price is picked up and the second is shipped and paypal'd.
Please do not pm me asking for parts that are not in this thread. I do not have them.
1) rear drivers side hub/knuckle and dust shield - $100, $125 - SOLD
2) rear passenger side hub/knuckle and dust shield - $100, $125 - SOLD
3) brake pedal - $25, $40
4) clutch pedal - $25, $40
5) trunk seal - $15, $25
6) brake booster - $40, $55
7) headlight support rubber strip - $5, $10
8) passenger side windshield molding piece - $5, $15
1) alternator from a ap1 with 32k miles - $60, $75 - SOLD
2) oil pump from a ap1 with 1k miles - $50, $60 - SOLD
3) abs module - $50, $65 - SOLD
4) brake master cylinder and reservoir - $40, $50
5) front ball joint - $15, $25
6) drivers side rear end link - $15, $25
7) front upper passenger side control arm - $25, $40 - SOLD
8) a/c receiver (black cylinder) - $15, $25
9) 3 - air pump relays - $20, $30 - SOLD 2, still have 1 left
10) eps module - $20, $30
1) e-brake handle - $10, $20 SOLD
2) differential mounts - $10, $20
3) battery/fuse box heat shield - $15, $25 - PENDING
4) clutch line - $5, ,$10
5) oem oil cooler - $20, $30 - SOLD
6) large underhood fuse box - $25, $35
7) small underhood fuse box - $15, $25
8) passenger side kick panel - $10, $20
9) wiper/headlight stalk assembly - $30, $40 - SOLD
1) diff mounts - $10, $20
2) water pump assembly - $65, $80 - SOLD
3) engine mounts powdercoated gloss black - $10, $20
4) brake proportioning valve - $10, $15
5) oem intake manifold gasket - $10, $15 - SOLD
6) 3 - vaccum tanks - $5, $10 each - SOLD 1, still have 2 left
7) bypass control valve assembly - $20, $25 - SOLD
1) ap2 transmission output flange - $30, $40
2) 2 - ap1 egr valves - $50, $60 each
3) diff mounts powdercoated black - $10, $20
4) oxygen sensors - $50, $60 each - SOLD blue and white ones, still have orange ap2 one left. this orange one is from the header and made by bosch.
5) cam position sensor - $10, $20 (i have like 10 of these)
6) oem ap1 fuel rail - $40, $50
7) random control boxes - make offers
8) air pump parts - make offers - SOLD
9) rear H emblem from a ap2 - $5, $10 - SOLD
10) cruise control box - $20, $30
1) passenger side a-pillar - $10, $20
2) rear tray plastic side pieces - $10, $25 for both
3) oem amber and 1 clear ap1 headlight diffusers - $10, $15 shipped each - SOLD amber driver side - still have clear d/s and 2 amber p/s - Clear one Pending
1) front abs sensors - 1 passenger and 1 driver's side - $50, $60 each - drivers side is sold. still have the pass side.
2) ap1 throttle body - $60, $70 - SOLD
3) front and rear H emblems from an 02 - $5, $10 each - SOLD
4) 3 - oem shifters - $20, $30 each
1) black rear tray - $20, $40 - sold the small piece, still have the large piece
1) ap1 cat with 32k miles on it - $80, $100 - SOLD
2) ap2 oem fuel pump with new filter (9k miles): $20, $30
3) black plastic oem fuel rail cover - $15, $25
4) ap1 oem thermostat with 32k miles on it - $5, $10
i also have an ap1 oem exhaust manifold with black heat shields. $50, $80
