scanguage 2 fitting
Old Aug 9, 2008 | 07:15 AM
timdon's Avatar
Thumbs up scanguage 2 fitting
just received my scangauge 2 from obduk i have just run the wire in but i am not sure were to put the gauge its self
i removed the 2 panels either side of the radio and fished the wire below the radio
then fed it up under the steering column and zip tie to the loom
then fed it up the side of the dash following my road angel cable
here are a few options to locate the gauge
any more ideas will be much appreciated
Old Aug 9, 2008 | 07:38 AM
m1bjr's Avatar
RV Mirror, cable up A frame and behind the sun screen panels?
There is a very good CNC item on ebay, search under scanguage.
This is radically better than the item on the GB thread too but unsure about clearance.
I am thinking about centre console, under the slider as it does little else!
Old Aug 9, 2008 | 07:55 AM
timdon's Avatar
thought about that but you can not see it when driving
Old Aug 9, 2008 | 10:08 AM
RobJ1's Avatar
More importantly, what do you think of it and does it work well.
We are just about to order 25ish in the group buy and I expect the guys would love some feedback from an S2000 owner first
Old Aug 9, 2008 | 10:39 AM
m1bjr's Avatar
http://www.ukobd.co.uk/gstore/store/g_view...p?idProduct=128
Old Aug 9, 2008 | 11:12 AM
timdon's Avatar
decided to go for this quick fix
as for the functions
air temp .water temp .rpm .mph.map.vlt.
all work well but i need to calibrate the fuel at my next fill up going to set up in gallons is the tank about 11 gallons ?.the one function that isn't working is fuel pressure
Old Aug 9, 2008 | 04:26 PM
NineBolts's Avatar
I don't the there is enough clearance above the mirror for that mount?
Old Aug 9, 2008 | 05:16 PM
SiCr's Avatar
You can *never* have too much information
Old Aug 10, 2008 | 03:26 PM
m1bjr's Avatar
Obviously, I was thinking of inverting it and having it below but maybe it woul;d obscure the view for taller drivers so having a rethink now mate.
I think it would live just above the radio door, off to the left a bit like you would pop a Brodit mount in behind the trim panel. A sliver of metal would go up under the dash and the radio door vents perhaps?
Timdon, looks like a minicab
Old Aug 11, 2008 | 12:36 AM
oxhouser's Avatar
I have an old radio door and i will try to fit it into the front so its flush or close to flush as it can be
