***SUPPLEMENT to the Official Exhaust thread***
Old Sep 24, 2008 | 07:31 AM
funat9000rpm's Avatar
Default ***SUPPLEMENT to the Official Exhaust thread***
This is a supplemental thread to the N/A forum's "Official Exhaust Thread". Please post your suggestions/experiences/warnings about NA set up exhausts here. I will of course be updating the thread as often as possible, whenever good new information comes in .
These are the PRELIMINARY threads that I've compiled, I will be updated as we go along...
Greddy TI-C vs. HKS
https://www.s2ki.com/forums/index.php?showt...&#entry13223486
"Exhaust info"
https://www.s2ki.com/forums/index.php?showt...=0&#entry614870
HKS install & pics
https://www.s2ki.com/forums/index.php?showt...=0&#entry313644
Fujitsubo exhaust install & pics
https://www.s2ki.com/forums/index.php?showt...0&#entry3692053
Supersprint exhaust install & pics
https://www.s2ki.com/forums/index.php?showt...=0&#entry206616
Amuse R1 catback discussion forum
https://www.s2ki.com/forums/index.php?showt...=0&#entry346388
Single vs. Dual part 1
https://www.s2ki.com/forums/index.php?showt...=0&#entry561450
Single vs. Dual part 2
https://www.s2ki.com/forums/index.php?showt...0&#entry3771050
Invidia info
https://www.s2ki.com/forums/index.php?showt...0&#entry3769346
Mugen & Comptech info
https://www.s2ki.com/forums/index.php?showt...0&#entry2243309
IF ANYONE HAS INFO THAT THEY WOULD LIKE TO ADD HERE (THIS POST), PLEASE PM ME!!!
BTW, any suggestions on comptech exhausts??
Old Sep 24, 2008 | 07:59 AM
SweetS2K's Avatar
I would like to see info. on the GReddy TI-c single exhaust system...
Old Sep 24, 2008 | 09:21 AM
iDomN8U's Avatar
Since this is a ALL OUT N/A forum, we know that singles are better then duals for ultimate power. 70mm seems to be the overall best setup, yet people say that 3" or 76mm is even better (Yet to see a Dyno proving this)
I think a thread that lists all after market exhausts with specs is a great sticky.
IE:
T1R 63mm V1 (Straight back Tip):
ID (Inner Diameter): 63mm
OD: Unknown
Weight: 15 lbs
Material: Stainless Steel Grade
Rough Power expectations: 7hp - 7lbs/tq
DB rating Idle:
DB rating at 6k rpm:
DB with Silencer at idle:
DB with Silencer at 6k rpm:
Drone range: 3000-3500
I know most of this info will not be avaliable, but it's comprehensive.
Old Sep 24, 2008 | 09:26 AM
57udl3y's Avatar
please delete this or change the name HvRRz is in the process of making one like the other two he already made and its better if he has the first post so he can keep updating it and all the information is right there at the top
Old Sep 24, 2008 | 09:41 AM
HvRRZ's Avatar
woops I did not notice that this had already been made. If the OP feels like going through the hassle of getting all the info I will gladly delete mine, and leave it in his hands.
Old Sep 24, 2008 | 10:43 AM
I will gladly update this thread, if you need some weight off your shoulders
Old Sep 24, 2008 | 10:47 AM
it will soon be a rarity, that's all I have for you :
http://www.autoblog.com/2008/09/10/japanes...res-bankruptcy/
Old Sep 24, 2008 | 10:50 AM
HvRRZ's Avatar
if you will make it anything like this: https://www.s2ki.com/forums/index.ph...f=213&t=634543
then great...otherwise it'll just become another exhaust thread that gets lost. If you can change the name that would be great.
Old Sep 24, 2008 | 11:00 AM
Terror's Avatar
I have the 5Zigen Pro Racer ASpec. I can't say what gains were had, as I never did a baseline run.
I did notice a slight increase in HP and TQ in the mid range (Butt Dyno ). This exhaust really came alive once I added the 60mm Berk Test Pipe. The sound is amazing and the power increase from the Test Pipe was noticeable.
It weighs in at almost 25Lbs. exactly and is a complete Stainless system with an Inconel tip.
