New York - Metro New York S2000 Owners Owners in New York City, Long Island, New Jersey, Connecticut
Need help drilling out a broken subframe bolt
Old Dec 8, 2008 | 06:17 PM
Js S2k's Avatar
Default Need help drilling out a broken subframe bolt
Hey guys,
As you may have seen, I snapped a 19mm sub-frame bolt when I was doing my clutch install. I highly suspect the threads are galled.
About 3-4 inches of the bolt are still let in the frame.
Are there any shops that you would recommend that can drill it out using a guide/ jig so they can drill as close to perfectly in the center as possible and then clean the threads with a tap?
mines13 maybe
I REALLY want to avoid having to cut the frame.
Thanks in advance.
James
Old Dec 8, 2008 | 06:28 PM
Jdmapl's Avatar
You can drill it out and rethread the hole. I never done it but i hear its not that hard.
Old Dec 8, 2008 | 06:31 PM
Js S2k's Avatar
I know this
I'd much rather pay a shop to do it since they can get the car up on a lift.
Also i just don't trust myself to drill it perfectly centered.
Old Dec 8, 2008 | 06:45 PM
2poor2mod's Avatar
is there enough of the bolt sticking out to get a welder in there and weld another bolt on, heat it up with a torch and remove the old bolt?
Old Dec 8, 2008 | 06:48 PM
Js S2k's Avatar
there is none of the bolt sticking out it is about 1-2 inches into the frame
Old Dec 8, 2008 | 07:26 PM
Nick.'s Avatar
if the car wasn't on jackstands i'd do it up for ya.
Old Dec 8, 2008 | 07:31 PM
Js S2k's Avatar
I will be taking it down this weekend. AAA FTW I can flat bed it anywhere within 100 miles I want.
How would you drill it so it could be as close to center and as straight as possible? \
This is not something would let anyone do free hand.
I have absolutely NO experience with this kind of stuff. Also, do you have the tap needed to re-thread it?
J's
Old Dec 8, 2008 | 08:07 PM
Neutered Sputniks's Avatar
A bolt puller might get the rest of what's in there out...so you wouldn't have to worry about it being the absolute straightest hole...and then just retap the hole.
I have a tap set if you guys decide to do this at home.
Old Dec 8, 2008 | 08:29 PM
Js S2k's Avatar
bolt puller? never seen one? would it work on a galled bolt this big?
Old Dec 8, 2008 | 08:35 PM
Possibly. I have the tap/die set, but not the bolt removal set. I'd say give it a try first - if it doesn't work, you can still just drill out the hole and tap it. Drilling out the hole and retapping it will require using a bolt a size or two up from the stock, so make sure you can find the right length bolt first...
