Choosing the Best / Correct oil
Old Dec 21, 2008 | 06:59 PM
dsddcd's Avatar
Default Choosing the Best / Correct oil
So I have read many opinions but I am looking for some background on what oils are the best to run with a non-water cooled turbo setup. I am no lubrication engineer and would apperciate any input
(1) What weight to use and why?
(2) If a heavier weight is suggested will it have adverse effects on the bearings, pumped volume, pump pressure......
(3) What type Synthetic PAO or other
(4) I use Mobile 1 now why does many people seem to knock it?
Old Dec 22, 2008 | 04:13 AM
Revenge's Avatar
My tuner uses Motul on my car.
Old Dec 22, 2008 | 07:02 PM
Envied's Avatar
I am using Amsoil 10w30 in mine since turbo.. Before that was nothing buy mobil 1
Old Dec 22, 2008 | 07:08 PM
evf2000's Avatar
Amsoil 10-30 and only that from now on.
Old Dec 22, 2008 | 07:56 PM
S2000 Cabrio's Avatar
Amsoil here too but in 5W-40 European Formula.....great stuff.
Old Dec 22, 2008 | 11:32 PM
asukadc's Avatar
motul 300v 10w40 since NA
Old Dec 23, 2008 | 06:30 AM
dsddcd's Avatar
Lets make this more techinical. If you go to a 15W-40 what impact will that have on the mainbearings? They are designed with particular oil weight and viscosity in mind. Changing these criteria may ruin the low end of the motor prematurly. Second what about the oil pump with a higher viscosity the pump will have to generate more pressure to obtain the same flow rate to the bearings, and at a higher pressure will the pump hold up and will the bearings be hurt?
Old Dec 23, 2008 | 06:38 AM
siadam's Avatar
[QUOTE=dsddcd,Dec 23 2008, 07:30 AM]Lets make this more techinical.
Old Dec 23, 2008 | 08:40 AM
DesertWanderer's Avatar
What about Amsoil? If you search their site they recommend 5W40 Euro formulation for our car. Why not 0W30? I need help too.
Old Dec 23, 2008 | 08:43 AM
RichV's Avatar
I use Mobile 1 10w30, but am changing to probably either Redline or Amsoil 10w40.
