some question for coilover and frame
Old Mar 3, 2009 | 09:33 AM
rhspyt's Avatar
Default some question for coilover and frame
hi, my 04 s2k main frame is like .5 inch off in right rear side, so instead of doing any frame work, i want to put coilover on it
so , in this kind of case, will it broke the coilover later on, cause one side is high , one side is down
and do you guy think it is a good way to solve the problem?
thank you
Old Mar 3, 2009 | 09:37 AM
thebig33tuna's Avatar
i can't wait to see the responses to this one.
get your frame fixed dude.
Old Mar 3, 2009 | 09:44 AM
istdercollen's Avatar
soyou want to adjust you coilovers to make you car look as though the frame isn't bent..... Sell your car. Take the bus. Goodbye.
Old Mar 3, 2009 | 09:47 AM
rhspyt's Avatar
wow, that is a good idea man ^^
Old Mar 3, 2009 | 09:48 AM
DDonovan's Avatar
Huh??? FAIL!
Old Mar 3, 2009 | 09:49 AM
okay.. I'll be constructive.. Why don't you use the money for coilovers and use it to fix the frame instead?
Old Mar 3, 2009 | 09:52 AM
you are right that it is a good idea. otherwise you'll kill yourself driving a car with one side lowered on coilovers.. anyway, read my constructive post beforey ou judge my 'unreasonable' suggestion of selling your car..
I wish Gordon Ramsey was an active member here.
Old Mar 3, 2009 | 09:53 AM
savesday04's Avatar
c'mon really??? fix the frame dude.
Old Mar 3, 2009 | 09:54 AM
rhspyt's Avatar
in fact, i am thinking it looks like just a little off..so i would like to use the money on coilover, also if i dont put coilover, i may need to buy the spring and shocks on the right side...so i just thinking to use coilover
Old Mar 3, 2009 | 09:58 AM
do whatever you want then. your frame is bent, so you should fix that, but it's your car. just make sure you tell the next person that want's to buy it.
