Nitrous S2K vs Stage 2 STI
My friend came home from college for easter break and has not stopped talking Sh*t about his STI. He is putting down 296 whp 326 wtq. I dont condone street racing but he just would not let up about how he would smoke me. He finally talked enough sh*t that i could not take it anymore. We did a pull w/o me spraying and he pulled a good 2 cars on me from 40-110. Not so bad i was expecting a little more out of him, after this i knew he was in for a treat. next run i sprayed a 75 shot and pulled at least 3 cars from 40 to 120. Probably the best feeling looking at his and his friends face. I put down about 285 whp on 75 shot. I knew he was not worthy of me spraying 100 shot. Just ran a compression test after and running 240 PSI in every cylinder
I been spraying the s2k for about 8 months now.
When you spray the 100 shot are you running race gas? Or have you get an EMS and pulled timing? Or do you just have some pretty big cahunas lol?
I know that I will be going nitrous @ some point in the future, after i/h/e, clutch and gears. I plan on doing the usual 75-80 shot.
I am pretty surprised the STI didn't get you by more than 2 cars without the spray. You have the stock gearing correct?
Your set-up=
Your set-up=
lol thanks men, i was very happy to see my compression test results came out perfect for every cylinder. I run it a lot but I always check plugs, and perform normal engine maintenance a little sooner. The system shuts it self off if it runs leaner then 11.5 to 1. $1500 bucks got me a bullet proof setup, 100 whp, and over 100 wtq.
too bad cops in CA always pop my hood other wise i'd look into this!
