Mark this thread as Sold
Delete
ABS Pump[/b]low miles 85 shipped
60 shipped
Ac Box & Blower Motor
This was actually the main reson why I purchased this car. I bought an "ap1" cluster and engine harness off another user and this showed up.
Ap2 Dash Cluster Harness 85 shipped
[IMG]http://s634.photobucket.com/albums/uu66/HondaPartsCo/S2000/th_4-1.jpg[img]
Axles Both look great, no rips in the boots 225 shipped for both
Ap2 Back Bumper Back bumper is OEM thats primered black. Came on the car when I bought it. I know its OEM becuase you can see the outline of the vin tag 200+ shipping
[B]Silver Stone Battery Tray Inlcuding All Hardware. 35 shipped
[B]o2 sensor 48k miles. Sensor is in great working condition, car had no CEL 50 shipped
o2 sensor 60k miles The guy who bought the shell threw in a complete exhaust as part of the deal. This o2 looks to be in great condition aswell 45 shipped
[B]Cat 48k Miles. This is the cat off my car, its in great shape and all the studs are perfect. 100 shipped
[B]Cat 60k. This is the cat i got in part trade. Its in great condition but one of the studs needs replaced. Should be an easy fix 80 shipped
[B]Charcoal Canister. I think thats the name of this. Its connected to the rear sub frame. Item isin perfect condition 35 shipped
Chassis Dash Harness Ap1. This is the harness that sits behind the dash. Great shape & uncut other than the plugs for the soft top and hazard switch 55 shipped
[IMG]
http://i634.photobucket.com/albums/uu66/Ho...ssisharness.jpg[/IMG]
Combo Switch. Perfect shape 35 shipped
Black Dash. Mind Condition, no rips or signs of wear. 230 Shipped.
Dead pedal Cover 15 shipped
Dead Pedal 20 shipped
Pass Side Differentail Mount 30 shipped
Driver Side Differential Mount 30 shipped
Rear Differential Mount 30 shipped
Dome Light/Sunvisor Plastic Cover 20+ ship
Dome Light 22 shipped
Driver Side Soft top plastic cover thing =) 25 shipped
Driver Side Door Glass 85 shipped
Driver Door Wiring Harness Uncut 50 shipped
Driver Front Brake Caliper With Brake Line & Pads 75 shipped
Driver Front Hub 120 shipped
Driver Upper Control A-Arm 100 shipped
Driver mirror with glass. Sebring Silver perfet condition 75 shipped
Driver Rear ABS Sensor 50 shipped
Driver Rear knuckle/hub. Wont Come with Axle 120 shipped
Driver rear Suspension Rod 50 shipped
Driver rear soft top cover 25 shipped
Driver side rear Plastic ( behind seat) 22 shipped
Driver Side
Driver Power Window Regulator 60 shipped
Engine Bay Fuse box comes with all fuses 30 shipped
Ap1 Engine Harness 100 shipped uncut
Exhaust 100 + shippin for the complete exhaust. 40 shipped for just the tips
Exhaust Header Heat Shield 35 shipped
Driver Floor mat keeper 20 shipped
Front lower Suspension bar 35 shipped
Front Sub Frame, Mint condition can do around 175 shipped
Fuel Pump 50 shipped
Fuel Release Lever & Cable 25 shipped
Rear Storage Glove Box 75 shipped
Exhaust header 100 shipped
Heater Core 75 shipped
Cabin Air Filter 25 shipped
Front lower Windshield trim 40+ shipping
Main Fuel Pump Relay 35 shipped
Front Lower Oil Catch shield. Its a being up from the accident but I think once it get installed and has some heat to it, it should go back to its original form no problem. None of the mounting areas are ripped 35 shipped
Pass door. Sebring Silver. Bare door shell, has some stuf inside but not much. Clean paint, no major dents, dings or scratches 225 shipped
Pass Door Glass 85 shipped
Pass Door Handle Sebring silver 30 shipped
Pass Door Lock Actuator 50 shipped
Pass Door Wiring harness 50 shipped
Pass Front knuckle 120 shipped
Pass front Upper Control Arm 100 shipped
Pass Lower Kick Panel 35 shipped
Pass Rear Abs Sensor 50 Shipped
Pass Rear caliper 75 shipped
Pass Rear Suspension Bar 35+ ship
Pass Plastic cover that sits behind the seat 25 shipped
Pass Soft top Plastic Cover piece 25 shipped
Pass Door Sill Plastic
Pass A pillar plastic
Pass Soft top tray 25 shipped
Pass Mirrror Sebring paint everythin works - 75 shipped
Pass Door Window Regulator 60 shipped
Pedal Assembly 40 shipped
Primary o2 50 shipped
Misc Plastic Piece
Radiator mountin brackets 20 shipped
Rear Bumper Support sebring silver 60 shipped
Rear wiring harness 75 shipped
Rear Sub Frame 225-250 shipped depending on location
Rear tray 30 + ship
Misc Plastic Piece
Rear tray 30 + ship
Black Plastic Trim From Rear Tray 20+ ship
Shift Knob 50 shipped some marks but still in good shape
Slave Cylinder 55 shipped
Soft top Mounting brackets 25+ ship
Srs Wiring harness 20 shipped
Starter 75 shipped
Steering Shaft 50 shipped
Steering Column with igntiion 200 shipped. Will come with 2 OEM keys and all the door locks & trucnk lock
Steerin Rack 150 shipped
Storage net 15 shipped
Struts/Springs 200 shipped
Sun Visors 40 shipped
Gold box 100 shipped
Sway bars 75 + ship for each. both come with end links
Rear Strut Bar 50 shipped
rear trunk hinges with springs 50 shipped
Trunk Lid Sebring 225 shipped
Electron Trunk Popper 35 shipped
heater duct box 25 + ship
Wiper Arms 35 shipped
Wiper mechanical arms 40 shipped
Wiper motor 40 shipped
Wiper Fluid Resevoir 35 shipped
Starter 75 shipped
Audio Control 40 shipped
Cruise Switch 20 shipped
Dash bezel 60 shipped
Driver Ecu kick Panel Cover 25 shipped
Hazard Switch 20 shipped
Head lights 600 shipped. head lights are complete and in great condition
Red Leather Console Cover 75 shipped
Soft Top Switch 20 shipped
Srs Cable Reel 40 shipped
Where everything came from =]
I used the cluster/ecu harness on my s2000
I only have the one that sits behind the dash. and it has the plugs for the hazard and top cut, otherwise its perfect. let me know if you're interested.
If you're intersted send 50 to TopNotchParts@gmail and I'll have it shipped today
