Sponsored by:
Sponsored by: CARiD
Stock air box mod.
Old Jun 2, 2009 | 05:36 PM
badboy00z's Avatar
Default Stock air box mod.
So I decided to gut the air box to get a better sound from the intake and hopefully better throttle response. Lol. I'll be getting a K&N air filter too.
Here are the pictures:
Before:
After:
I used an old flimsy steak knife that I had which wasn't such a good idea as it flexed a lot. Tried using a demel but I couldn't get a good angle to work with so I continued with the knife. After sawing a bit I used a pair of pliers and broke it off in small pieces. Took me longer than I expected as the plastic is pretty damn tough.
I'm guessing the 2 smaller holes are the drain holes. Should I make them bigger?
I still have to sand it down a little more to get it smooth and flush with everything.
I didn't do the cover yet because I don't know how I should go about removing the elbow scoop.
Alright, so I managed to remove the elbow scoop using a wire cutter and just started cutting away at the studs. Came off really easily. The top part of the divider came out easily too. I just grabbed it with pliers and broke it off. Luckily it broke off flush.
Also now that the divider is gone, should I put mesh on the front intake hole to prevent stuff from getting in?
All that's left is to get the K&N filter...
Old Jun 2, 2009 | 06:30 PM
SixToeRen's Avatar
Originally Posted by badboy00z,Jun 2 2009, 05:36 PM
Any idea as to how I should remove those? I'm think about drilling them out.
I just used a large pair of pliers and yanked it off. Heres a picture of my old intake.
Old Jun 2, 2009 | 07:30 PM
badboy00z's Avatar
Thanks. Should I bother with blocking off the hole to the resonator chamber?
Old Jun 2, 2009 | 08:02 PM
Back S2k's Avatar
get a snorkle
Old Jun 2, 2009 | 09:00 PM
JohnnyP912's Avatar
Yes block off the resonator chamber with some aluminum tape.. ^ snorkel might not be as effective without the elbow on the lid..
Old Jun 2, 2009 | 09:52 PM
iam7head's Avatar
why not just use the stock drop in k&N and keep the L shaped air guide?
it's directing air str8 onto the top of the filter like it's designed to, now you don't even have a clean path for the air to go to
Old Jun 2, 2009 | 10:00 PM
badboy00z's Avatar
I can always super glue the guide back on. Lol.
Old Jun 2, 2009 | 10:04 PM
iam7head's Avatar
you sure can, but for a permanent fix, try plastic fusion epoxy
Old Jun 2, 2009 | 10:14 PM
Deception's Avatar
thats what im thinking
Old Jun 4, 2009 | 11:45 AM
alSpeed2k's Avatar
Would the guide fit with that monster intake on?
