Sponsored by:
Sponsored by: CARiD
any open ended lugnuts/cool lugnuts on stock rims?
Old Jul 1, 2009 | 12:31 PM
street_ruler's Avatar
Default any open ended lugnuts/cool lugnuts on stock rims?
hey anyone out there know if anything cool looking lugnuts will fit a stock wheel? i like the look of the open ended lugnuts with the finger grips on the end (little texturing). i wanna run extended lugs and open ended lugnuts just for a little different look.
any suggestions?
Old Jul 1, 2009 | 12:39 PM
9K-S2K's Avatar
Usually aftermarket lug nuts are tapered and should not be used on stock wheels.
Old Jul 1, 2009 | 01:29 PM
right....i get that thus im asking if any are geared for us that wanna keep the stockers
Old Jul 1, 2009 | 02:22 PM
Terror's Avatar
No.
Old Jul 1, 2009 | 02:54 PM
aznives3's Avatar
get your stock's powdercoated like mine!
Old Jul 1, 2009 | 03:39 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Old Jul 1, 2009 | 04:02 PM
MMM.PWR's Avatar
how did you nut scratch the paint off when you torqued them back on? were you extremely careful?
Old Jul 1, 2009 | 04:17 PM
JSWhaler's Avatar
Those look great powdercoated. Does the coating come off easily on the lugs?
Old Jul 1, 2009 | 04:28 PM
LostMotion's Avatar
I'm a bit confused with this since I though the OEM wheels were lug centric and could use any aftermarket lug. If you compare a stock lug to an aftermarket, the taper looks the same as well. I certainly could be wrong. I used the stock lugs with aftermarket rims for a couple days and they seemed to fit quite well.
Old Jul 1, 2009 | 04:58 PM
nte11igence's Avatar
You're wrong. The taper is different. OEM lugs are acorn shaped and most aftermarket lugs are cone shaped.
