Question about wheel alignment specs
i am getting new tires mounted...
the guy at Northstar told me to ask you guys about the alignment specs you are using...
anyone know the stock alignment specs??
what kind of alignment adjustments should i ask for... different than stock ones since i autocross these street tires??
please give me input... thanks.
teddy
teddy
If this is street/autocross and all other suspension components are stock, try:
Front:
Caster +6.5 degrees
Camber -1.5 degrees
Toe 0
Rear:
Camber -2.2 degrees
Toe 3/8" total in
Let me know what you think. If the tail keeps coming out on turn exits go to a 1/2" toe in the rear, but it won't be very streetable after that.
Front:
Caster +6.5 degrees
Camber -1.5 degrees
Toe 0
Rear:
Camber -2.2 degrees
Toe 3/8" total in
I don't remember exactly but I think its something like:
Front:
Caster +4.0
Camber -0.5
Toe 0
Rear:
Camber -1.5
Toe 1/4" total in
The factory service manual has the info, but I don't have it in front of me.
Front:
Caster +4.0
Camber -0.5
Toe 0
Rear:
Camber -1.5
Toe 1/4" total in
Factory alignment spec
Front
Camber -0.5d +/- 0.17d
Caster +6.0d +/- 0.25d
Total Toe In 0+/- 2mm
Rear
Camber -1.5d +/- 0.17d
Total Toe In 6mm
Honda (UK) Recommended Optimum Specification
Front
Caster Left 6
Front
Rear
Total Toe In 6mm
Front
Caster Left 6
Hello All,
I am having a hard time deciding what amount of toe out or toe in to use in the front. I thought I liked toe in, but I'm not sure, as I had the negative vs positive mixed up so I don't really know what was on my last car.
Anyway, I was wondering what the majority of you guys like/use.
Thanks,
Mike (aka ThankyouHonda)
Thanks,
