S2000 Homecoming Part 2
It has returned!!!
All though it is in planning stages right now, and not officially going to be happening, if you follow the link below you will get all the details you need/can have at this point. There are a lot of vendors that have said they will support this cause. Sounds like there are going to be several raffles for some cool things, one is a set of custom made seat covers and another is a kit that can change the LEDs on the dash board to a custom color.
There is going to be a limit on the number of people that can go, so sign up early! You don't want to be left out!
September 2010ish is going to be the 2nd S2000 Homecoming (if everything falls into place). It was a blast when I went in 2007, should be even better this time.
Let's get a good representation from the Oregon/SW Washington group!
I'm in Doug. I hope everything falls into place. I saw this thread back in June, I see it has grown significantly since then. I really hope it's similar to the 2007 one with Honda backing it.
Saying you are in here doesn't count for a hill of beans. Even if you aren't sure you can make it, just put your name on the list so that you can back out. Once it is full, there is noway you can get in. If you are in, and can't go, then you can always back out.
Get your name on the list TODAY!
