factory stability control on 06+
Old Nov 16, 2009 | 09:01 PM
socals's Avatar
Default factory stability control on 06+
in the 06+ ap2's is the factory stability control part of the ecu or controlled by a seperate ECU?
Can hondata allow control of factory stability control. Say you would like more yaw angle before the VSC interupts? and / or is their a way to soften the abrubtness of the factory VSC, (ie lessoning the amount of time it takes throttle input away from you when vsc engages?
Thanks
Old Nov 17, 2009 | 05:59 AM
Hondata's Avatar
VSA is intergrated into the ABS unit, and not controlled by the ECU.
Old Nov 17, 2009 | 10:43 AM
ace123's Avatar
You can sort of cheat--turn the wheel a little more than you want to and VSA will relax and let you rotate a bit more. Not the way you ideally do it, but if you want much more than that for headroom and control you just have to defeat the system and do it manually. It seems to be designed as a net for safety, not a competitive traction control system.
But in my experience, it's very rare for VSA to do anything but make rather subtle corrections. It's not even jerky in snow/slush/etc (on snow tires). It only jerks when I immediately go well beyond the limits of the tires, i.e. if I were to drop the clutch in 2nd while going around a corner near the limits.
Old Nov 23, 2009 | 11:47 AM
macr88's Avatar
I thought that little check box for VSA would disable it
It's only letting the ECU know you have it, is that correct?
Old Nov 24, 2009 | 06:25 AM
Hondata's Avatar
Checking VSA box enables the ECU to VSA communication - it does not disable the VSA completely.
We recommend that people keep VSA enabled unless they have physically removed the VSA (which is part of the ABS). If you want to disable VSA, use the button on the dash.
Old Nov 25, 2009 | 01:17 AM
macr88's Avatar
It's actually quite interesting the way it works with the check box unchecked. I kind of like the fact that it doesn't shut the throttle on you.
Old Nov 25, 2009 | 07:14 PM
thesilverbullet's Avatar
interesting - how does vsa work when disabled? no throttle cut but still applies the brakes?
Old Nov 25, 2009 | 08:00 PM
macr88's Avatar
Yup, I wouldn't go crazy with it though, you don't want to burn through your brakes.
Old Dec 3, 2009 | 09:17 PM
sweeeeeet - does that help traction on a 6k launch?
Old Dec 4, 2009 | 04:36 AM
macr88's Avatar
^I have no idea.
