Today I just wanted to test fit my TE37s. I have the sets of hub rings and a 3mm spacer from T1R for the rear. The hub rings I have have a part on them that is not contacting the hub when the spacer is on. To show what I am talking about I took a few quick (crappy) pics pointing to what I am talking about.
I want to know if I can get hub rings that do not have that part that is sunk in. I need them to come straight out and be flush.
I don't know if I am explaining this right, but if you somewhat understand, please help.
i guess based on your pictures, would it be possible to put the hub ring on the car first, then the spacer? i mean would the spacer fit around the hub ring?
I am running a SMALL spacer, not one that will push the wheels out too much. I know everyone else will say they can not notice a 3mm spacer, but I honestly can on my car. I only got a 3mm spacer to flush up the wheels. I don't want to get a 10+ spacer because it would be too big and not let me run a 255.
Anyways, I can not install the spacer over the hub ring. I tried. Also, if I get plastic ones or rubber ones will there be a problem with them melting when I track the car?
If your dead set on running the spacers then I think the plastic ones will be fine. I have them but i dont track my car. You will also be fine not running any like 99% of people do.
Well, what are the negatives of not running them? I mean, there is a lot of space between the 64.1 hub and the 73 wheels... Not a lot, but enough for me to be skeptical.
I don't have rings on the wheels I have on the car now, but I can feel a vibration that I suspect may be because of there being no hub rings. The wheels on the car now have a larger than 73 center bore. They balance up great, so I know it's not from that.
Does anyone have the Ichiba 5mm spacers? They look like they have a built in hub ring...
