08 CR with Toda Spec C Cams and FPro
Old Jan 18, 2010 | 06:57 PM
jei_s2k's Avatar
Default 08 CR with Toda Spec C Cams and FPro
Here is a recent Toda C cam install dyno:
Owner: Kevin aka kevs2kCR
Car: 08 CR
Mods:
-Toda header
-Toda test pipe
-Toda 60mm Dolphin exhaust
-Toda C's (thanks to Bulletproof Automotive)
-Hondata Flashpro (thanks to Hondata)
-Everything else stock
Dynoplot#1 - 2 baseline pulls off Untuned Stock OEM ECU, no change except for cam install. AFR's displayed on right. Notice it lean out at 5k rpms+. We let off the dyno anticipating it would lean out further.
Same Dynoplot#1 showing HP & TQ again Untuned Stock OEM ECU. At 7k rpms power is close to what AP2's yield stock
Below, HP & TQ graph - comparison from completely stock AP2 vs Fpro Tuned
Most of the editing was in the fuel map mostly from 4k rpms up. Upgrading to an aftermarket intake and a larger diameter exhaust, we expect this to yield higher numbers. Details HERE
4/20/10. Due to requests, I found a comparable Flashpro Tuned F22 with Toda Header for another comparison. Please note: This is a different car so it is not an apples to apples comparison but the most comparable dynoplot I have on file. Both cars used in this comparison had OEM intakes, 60mm test pipes and 60mm exhausts. Noticeable gains are from ~6k+
Reference:
purple (...) line = Stock F22 Toda Header Flashpro Tune
purple (._._._) line = Stock F22 with setup posted at top of thread
Old Jan 18, 2010 | 08:14 PM
Mrfixit687's Avatar
Do you guys know if the spec b's will need the exhaust rockers grinded down?
Old Jan 18, 2010 | 10:10 PM
QuagmireS2k's Avatar
Nice increase in the midrage department.
Old Jan 19, 2010 | 07:21 AM
AP2CRazy's Avatar
+1. Are the numbers measure at the hubs or wheels?
Old Jan 19, 2010 | 08:17 AM
UMS Tuning's Avatar
its a DynaPack...measured at the hubs....
focus on the gains..not where its measured.........
Looks good, nice work!
Old Jan 19, 2010 | 08:44 AM
jei_s2k's Avatar
If you look at the Toda site the B's and C's share the same primary and secondary lobes so based on that information I would assume you will need to clearance the rockers for B's.
Old Jan 19, 2010 | 09:25 AM
Gernby's Avatar
Is VTEC at around 4700 RPMs?
Old Jan 19, 2010 | 02:23 PM
kial007's Avatar
Looks good! How streetable is it?
Old Jan 19, 2010 | 03:27 PM
kevs2kCR's Avatar
man the drive is awesome feels stock until you press on the gas hahaha
Old Jan 19, 2010 | 03:36 PM
Mrfixit687's Avatar
Any pictures on what you need to do to the exhaust rockers?
